Idling problems with ac
Old Aug 7, 2004 | 07:57 AM
JDM97R's Avatar
Default Idling problems with ac
Hi guys ,
Why when i switch ac on the idle goes down to about 500rpm and don't go up to 1000rpm as usual?
Need help please.
Old Aug 7, 2004 | 10:24 AM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default Re: Idling problems with ac (JDM97R)
When you turn on the AC the AC belt starts spinning off the crankpulley which sucks up some power from the crank. The engine needs to compensate for the power lost when the AC compressor starts to spin its belt. Its normal.
Old Aug 7, 2004 | 10:27 AM
JDM97R's Avatar
Default Re: Idling problems with ac (Nvious R)
Thanks for your info but i know that you told me is normal,before i done the rebuilt it was like that but now remains low idle when i switch it on
Old Aug 7, 2004 | 11:28 AM
len's Avatar
len
It is not normal for the idle to fall down to 500 RPMs and remain there when the A/C system is switched on. It is however normal for the idle to drop a little and the ECU will compensate and you will idle higher than if the A/C system wasn't on.
May I suggest checking to see if all vacuum lines are connected or connected properly. That's your first step. The second step is to see if any CEL are thrown. Then I would do a compression check for all cylinders. When I stretched my valves I had a weird idle similar to the one you described. Also, right now, my car is doing the same and it is due to compression. I installed ARP head studs and I haven't gotten around to retorquing them. I know it's this because oil has accumulated between the block and the head. On top of that, I smell coolant.
Old Aug 7, 2004 | 11:59 AM
jdmspoonitr's Avatar
Default Re: Idling problems with ac (len)
Yep...Len is correcto. Whenever I turn anything on my idle goes higher not lower. That goes for the headlights, a/c, whatever...
konaKevin
Honda CR-V & Element
Aug 5, 2013 11:40 AM
LONO100
Feb 1, 2012 08:13 PM
Rooftop-Special
Sep 2, 2010 08:08 PM
blackludebosh
Aug 9, 2008 01:33 AM
ek9mugen
23
Apr 10, 2004 10:32 PM
