FS: Bullseyepower Turbo S259
Bullseye Power/ Borg Warner custom turbo: S259 w/ billet compressor wheel .55AR (supports 300hp-550). T3 manifold size. Less than 5k on it. Paid $1550 no shaft play/good seals, asking $1000obo Best performing turbo of its size in the world (compressor map dominates GT30r), spools up as fast or faster than ball bearing but is actually rebuild-able.
Compared to a T67, the S200:
- Runs higher boost safely and more efficiently
- Spools quicker
- Produced up to 100 WHP and 80 WTQ more
- Maintains higher levels of power and torque a full 3000 RPM longer
By extending the ends of the compressor wheel, Bullseye Power has effectively increased the pressure ratio, efficiency and flow of the entire compressor. This gives the S200 and S300 pressure ratios and efficiencies that can normally only be had with larger, slower spooling turbos.
623-764-1988
- Spools quicker
623-764-1988
**EFFECTIVE IMMEDIATELY**
From todays date (3/18) onward; anyone selling ANY product in the marketplace will be expected to post a picture of their item for sale with a sign included in the photo. On the sign, should be your username, date and the words Honda-Tech.com on it. It can be handwritten or printed on a piece of paper. No photoshopped signs will be accepted.
2kdrift
Aug 28, 2015 07:15 PM
