New distributor/timing issue, HELP!
Old Oct 9, 2013 | 10:05 AM
z7rix's Avatar
Default New distributor/timing issue, HELP!
I have a EG with a D15Z1 and my distributor so, I bought one on craigslist off a D16y8 and only two of the bolts line up correctly, but it still goes in. And when I start the car its not igniting all the cylinders. Could this be from the distributor or is my timing just really off? If it is from the distributor I was thinking about taking out the internals of the old distributor and replace it with the new one in the old housing so it can bolt right up, would this work?
Help me out! I need this fixed ASAP.
Out of line bolt
Old Oct 9, 2013 | 10:31 AM
Allboutthe305's Avatar
Default Re: New distributor/timing issue, HELP!
is it a d15z1 complete motor or a d15z1 block with y8 head?
Old Oct 9, 2013 | 10:36 AM
Compared the housings and make sure the bolt holes line up. I personally dont think the y8 distributor bolts up to that head perfectly.
Old Oct 9, 2013 | 10:37 AM
kyden's Avatar
i'm confused. is your car wired for an obd2 distributor?
Old Oct 9, 2013 | 10:44 AM
I was just getting ready to say that also Kyden
Old Oct 9, 2013 | 10:46 AM
z7rix's Avatar
d15z1 complete, only a y8 dizzy
Slightly different
Old Oct 9, 2013 | 10:50 AM
z7rix's Avatar
I converted the harness from obd2a to obd1 on the dizzy
You can see the difference in bolt patterns in the pictures. It wont bolt up all the way perfectly. And is your car wired for an obd2 distributor? is it all still obd1 wiring?
Old Oct 9, 2013 | 10:56 AM
z7rix's Avatar
I used the harness from the obd1 distributor and wired it to obd2 distributor
96a-ccord
Feb 26, 2010 02:04 PM
melissashelton1
Feb 4, 2010 05:16 PM
RA61825
Mar 12, 2006 02:26 PM
d15b7racer
Jan 7, 2005 04:26 PM
fire7882
Jun 24, 2002 05:37 AM
