cel on after 00 b16a2 swap into 98 hatch - code reader not recognized
Old Oct 7, 2013 | 07:17 PM
Pat_Black's Avatar
Icon2 cel on after 00 b16a2 swap into 98 hatch - code reader not recognized
I need help guys. I recently swapped a 2000 b16a2 into my 98 cx hatch. I used the wire harness and computer from the 00 si. I have a check engine light on and when I go to check the code with the machine the machine does not recognise my car. Now this is only my second swap, first one on a obd2 car so I'm not too familiar with obd2a and obd2a thing. My friend told me it may be bc I put and obd2a swap into an obd2b car, or vice versa and the car harness in not working with the engine harness and ecu. How do I fix this problem? Will I have to swap the entire harness and ecu or is there a simpler fix? Any input would help.
Old Oct 8, 2013 | 01:37 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Help with cel on after swap.
You can't use the 99-00 harness without the interior harness as well. You can use a 96-98 Ex Harness for mostly plug and play. Or use the dx harness and add the additional wiring.
Old Oct 8, 2013 | 06:39 AM
Pat_Black's Avatar
I'm confused. Are you saying to switch my interior harness to one of these ones?
Old Oct 8, 2013 | 07:21 AM
kyden's Avatar
no. he's saying to use the engine harness from a 96-98. did you do any research before swapping?
Old Oct 8, 2013 | 08:45 AM
b20hatchek's Avatar
and also maybe getting a jumper harness and run a p28 ecu
Old Oct 8, 2013 | 10:04 AM
Pat_Black's Avatar
It was a quick swap bc my other car got totalled to I need it done fast so no I didn't do any research. I was also busy doing an auto to manual swap while my friends, who have done way more swaps than me were doing the engine swap and failed to tell me this was gonna be a problem. I can't put it on them though it's my car so I should of done the research. So if I use the 96-98 harness will it work with the 00 si computer or will I have to run a p28. Which would be easier/cheaper, swapping out the whole harness or running a jumper harness to a p28?
Old Oct 8, 2013 | 10:07 AM
Pat_Black's Avatar
Default Re: cel on after 00 b16a2 swap into 98 hatch - code reader not recognized
I just looked up a jumper harness on rywire. Seems like spending the money on that and running it to the 00 ecu would be easier than using the 96-98 harness bc it's also an automatic harness.
Old Oct 8, 2013 | 11:04 AM
Technical Hero
Which harness are you looking at?
Old Oct 8, 2013 | 12:59 PM
Pat_Black's Avatar
http://www.rywire.com/catalog/obd2a-...ness-p-20.html
Old Oct 8, 2013 | 02:47 PM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
You need to run the harness that came with the car.
Old Oct 9, 2013 | 01:03 AM
Technical Hero
Use the harness the car came with. Add the wiring for vtec, knock and IACV conversion. Extend the second 02. Then you can use an OBD2a to b ecu adapter.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-honda-engine-swap-wiring-guide-vtec-non-vtec-2987229/
Old Oct 10, 2013 | 10:13 AM
Pat_Black's Avatar
So I'm gonna have to pull out the 00 harness and switch it with the 98, run all those wires then use the adapter to the 00 ecu? That's the easiest way? The adapter won't work with the 00 harness to the 00 ecu?
Old Oct 10, 2013 | 11:48 AM
Technical Hero
The link will tell you all but in a nutshell
1. Use 96-98 ex harness, wire in 2nd 02, ecu adapter
2. Use the 98 harness, do all the additions above plus the ecu adapter
3. Replace your interior harness with a 99-00 ex or Si
Old Oct 13, 2013 | 12:22 PM
Pat_Black's Avatar
Why would I replace the interior harness with a 99-00 if I'm gonna put the 96-98 engine harness back in. Does anyone know if my situation would also cause my speedo and tach to not work. I'm assuming since the interior harness is still the 96-98 and the engine is a 99-00 that the speedo sensor isn't matching up. Am I right?
Old Oct 13, 2013 | 12:28 PM
Former User's Avatar
The 99-00 Civic harness gets the tach signal from the ECU whereas the 96-98 harness gets the tach signal from the distributor.
Old Oct 13, 2013 | 03:27 PM
Technical Hero
I was giving you 3 options
Old Oct 13, 2013 | 04:29 PM
94EG8's Avatar
Seagull Management
You don't, you do one or the other. Both harnesses need to match is the point. You can't mix a '96 - '98 harness with a '99 - '00 harness. As long as both the engine and cabin harness are the same OBD type you'll be ok.
Yes. The green plug that connects the engine harness to the dash harness is pinned differently between the two and as Ron said OBD2 get their tach signal from the ECU rather than the distributor.
Old Oct 14, 2013 | 08:35 AM
Pat_Black's Avatar
Oh my bad I read that wrong. Well thanks guys, this has been a huge help.
CodyGt3076r
19
Sep 27, 2012 12:53 PM
D_koschak
Jan 21, 2011 05:46 PM
EF7
Sep 25, 2006 09:06 AM
4g4me
Feb 21, 2003 12:11 PM
SC61HB
Jan 27, 2003 01:56 PM
