Clutch/Slave cyl problem -- help!
Old Oct 2, 2013 | 01:18 PM
NoSwapNoCare's Avatar
Default Clutch/Slave cyl problem -- help!
Ok so I was leaving work last night, I pushed in clutch to start the car, I go to put it in reverse and it won't go into gear. Pedal is now dead. Looked in master cyl reservoir and it was empty. So I put some more fluid in and start manually pumping the pedal. Now there's a spot underneath the slave cyl with fluid. Can anyone help me here? Is it the slave cyl? Just a line leaking? Tyia!
Old Oct 2, 2013 | 03:35 PM
fcm's Avatar
fcm
Old Fart
Default Re: Clutch/Slave cyl problem -- help!
Hard to say if it is the SC or the line, wipe away all fluids, [clean] and see exactly where it's coming from. 94
Old Oct 2, 2013 | 04:22 PM
Wiped down its def coming from slave cyl. Is best course of action just replace sc and go from there?
Old Oct 2, 2013 | 10:57 PM
holmesnmanny's Avatar
pull back the boot on the slave cylinder and look for a leak there...just for the hell of it check the master cylinder push rod behind the clutch pedal and see if it's leaking at that push rod..if so, replace both if both are leaking...best to do em both at the same time...don't buy auto parts stores brand master cylinders they all sell junk and will leak at the push rod almost immediately...either go honda oem or buy ac delco or something trustworthy
Tkrizz
10
Nov 6, 2015 10:20 PM
WillyD
Transmission & Drivetrain
Oct 1, 2011 10:04 PM
zc89hatch
Apr 1, 2008 05:37 AM
Honduh Uhcord
Oct 15, 2007 08:29 PM
92eg6lsvtec
May 20, 2006 05:56 AM
