Custom exhaust help
Well im pretty sure that custom is the way for me. i have a 92 vx and my 2.5" dp should be here anyday and im tired of running my stock vx exhaust(its soooo small). what is a recommended muffler and i have a friend who can weld steel(but not Al), so info on parts to buy, what mandrel bends etc would be very very helpful. and im trying to keep the costs looooowwwww. let me stress low.
For the mandrel piping go to http://jcwhitney.com/product.jhtml?CATID=180618&BQ=jcw2 and be creative as to what bends you need.
For the muffler, I've heard good things about the N1-style canisters.
how about two 90 bends for the b pipe or one u bend if that's cheaper...and two 45's for the over the rear lower control arm. the 45's go like this:
>> ____ _(muffler)
_/(lca here)
____________ground
I like magnaflow mufflers and jc whitney bends
Brad
[Modified by Brad, 3:33 PM 10/26/2002]
>> ____ _(muffler)
_/(lca here)
____________ground
Brad
where is a good place to get the flanges and hangers? and should i get a resonator? and is the aluminized steel fine for exhaust, or should i get ss? the "aluminized" stuff is just an anti rust coating?
[Modified by blufke, 11:37 PM 10/26/2002]
I got the flanges from a local exhaust shop and made the hangers out of a solid steel tube from home depot though you could get the hangers from an exhaust shop too.
Brad
Brad
I used aluminized steel and round magnaflow mufflers as resonators. I used two resonators, but you probably could use just one or none if you don't mind the noise.
Brad
Brad
jc whitney charges too much for their bends, if you wanna keep the cost down order from summitracing.com, get the dynomax mandrel bent piping, youll save 30-50% if you go with dynomax bends.
hurry up with your exhuast so i cant beat you already! You know who this is.
i got a custom downpipe from my turbo made from a muffler shop, then i bought thermal r&d exhaust that bolted right to that. it was alot easier that way.
sure old man. whatever. how about when i put my turbo on. then we will see how your hearse does.
And I will still whomp on you. And by the way Its a Lincoln not a caddy.
its a hearse because it usually carries around things that are dead or are almost there. hence you being an old man.
maybe this one because of its color but I think I should put a hitch on my car to hual yours after it dies on you. Then I guess you could call it a hearse
lamer![Modified by bacardi, 6:19 PM 10/29/2002]
djay86
Sep 23, 2002 02:51 PM
