cel6, cel23, cel45 need help
Old Oct 26, 2002 | 08:54 AM
pennies_hatchie's Avatar
Default cel6, cel23, cel45 need help
okay, i need all the help i can get on this one....check out the link below
https://honda-tech.com/zerothread?id=310917
[Modified by pennies_hatchie, 2:13 PM 10/26/2002]
Old Oct 26, 2002 | 10:56 AM
Viorent GRIP!'s Avatar
Default Re: cel6, cel23, cel45 need help (pennies_hatchie)
link doesn't work, try again.
Old Oct 27, 2002 | 08:52 AM
try now
Old Oct 27, 2002 | 09:15 AM
NiiS's Avatar
what do you want to know...?
6= engine coolant sensor
23= knock sensor
45... no clue
Old Oct 27, 2002 | 10:29 AM
ill phil's Avatar
Default Re: cel6, cel23, cel45 need help (sinister)
Have you ever checked a sensor for reference voltage or resistance? If you you can put a DMM to the sensor after the car has been running and find the resistance which is representative of the temp. You can find a chart, that shows what temp=what resistance and compare. This will help you determine if the sensor is going bad. You can also check reference voltage to the harness that plugs in to the sensor.
At any time did you try replacing the thermostat?
Rule of thumb- start with the lowest numbered code first (Code 6) usually after eliminating that code the others may go as well (which in this case seems logical).
Old Oct 27, 2002 | 12:07 PM
Default Re: cel6, cel23, cel45 need help (ill phil)
okay, i dont have a way to check which sensor it is. i know that when my engine gets hot, the fan doesnt turn on. i've already replaced that sensor and the fan doesnt turn on still. so what ive done is have a direct link to the fan. maybe this is the reason why code 6 is being thrown. ive checked my knock sensor and it seems to be okay, and yes it's plugged in. but the rpm is still going nuts (it'll jump from 4000 to 4500 rpm when at high milege but when im doing only 30-50 it'll idle normal) dont know what else can be wrong with the knock sensor. as for the 45, im getting backfire from the engine. i know that i must be running fuel too rich but how do i correct that? thanks any input on my three problems would be good!
Old Oct 27, 2002 | 12:20 PM
ill phil's Avatar
So you've already replaced sensor for the fan? But you can't check the ECT sensor? I'm lost on what you're saying.
Old Oct 27, 2002 | 05:56 PM
gamby's Avatar
Code 45 is too rich/too lean fuel mixture. Anyone who messes with a V-AFC, cams/gears or fuel pressure regulator on an OBD2-equipped car gets well-acquainted with that code.
I hate it
Solution? P28 ECU or Hondata.
Old Oct 27, 2002 | 07:11 PM
Default Re: cel6, cel23, cel45 need help (gamby)
okay, what i mean by replacing the water temp sensor is that i was trying to trouble shoot 3 of the sensors that is involved with the water temp. i replaced the sensor that turns on/off the fan because the fan didnt work (sounded logical). well turns out the fan still didnt work, and i was already drained on $$. so i decided to just connect the fan direct to a switch. anyways, for the knock sensor, turns out that the black plastic piece is broken and the metal inside it broke off from the metal piece that connects to the engine. so if im right, all i have to do is replace the bad knock sensor with a good one and my trouble with the knock sensor would go away right? okay with cel 45, how am i going to correct this. i know that my engine is running too rich, but how do i get it back to normal.
thanks
Old Oct 28, 2002 | 08:36 AM
ttt
Old Oct 28, 2002 | 09:01 AM
ill phil's Avatar
Do you know what your fuel consumption is? Like as in mpg compared to normal?
Old Oct 28, 2002 | 10:38 AM
well not really, because i just did the swap and got the codes thrown at me, so i have no idea on how much gas the thing eats
Old Oct 28, 2002 | 10:50 AM
ill phil's Avatar
Do you know how many MPG you are getting per tank since the swap? I may be off here in my thoughts, but you could check your fuel pressure and see if its dropping - could have a leaky injector that would cause a rich fuel condition.
Old Oct 29, 2002 | 12:36 PM
well i checked the injectors and they look fine, still dont know how i would go about fixing the fich fuel, cause im gettting a lot of backfire when i start the car (w/out pushing on gas) once im driving it, the car doesnt backfire anymore. also, is there a way to get rid of cel 23 other than replacing the ks or getting a chipped p28. by the way, if i was to put in a new ks, would that usaully take care of the problem?
Old Oct 31, 2002 | 08:49 AM
ttt
MacMade
Mar 18, 2015 06:42 AM
jdmjackson
Jan 30, 2013 04:31 PM
99d-series
May 1, 2009 08:56 AM
spag
Sep 13, 2006 04:07 PM
jdmboy1825
Mar 10, 2005 12:02 PM
