98 civic crank no start
Old Sep 18, 2013 | 03:58 AM
lovemyhonda1's Avatar
Default 98 civic crank no start
I went on a two week long vacation and parked my car. When i came back it started and ran just fine, until after i drove it for about 5 miles and then it stalled and died. I was able to restart it a few times and it ran like crap and died. Now car won't start at all. I checked for spark and fuel pressure. I get spark at all of the cylinders and am getting approximately 3bar fuel pressure upon turning the key on. I checked for codes and i only have a cat. efficiency code stored. Also i believe the check engine light was on when i first started it and went off after the car stalled. I removed the spark plugs and all were flooded with gas. I cleaned them up and reinstalled back into the car. At first i thought that i could be getting a weak spark so i replaced the ignition coil and car is still not starting. Also i checked for a crank signal with my scan tool and it shows an rpm speed when i crank the car. I am also going to perform a compression test on it but it sounds like its getting good compression when i crank the car. I did removed the oil filler cap and check that the rockers are moving so the timing belt should be fine. please help.
Old Sep 18, 2013 | 11:56 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: 98 civic crank no start
Find out what the CEL is for. That should lead you in the right direction of your problem.
bustedhonda95
40
Oct 23, 2019 07:39 PM
olegles11
15
Feb 23, 2013 02:53 PM
hollowman8904
Jan 7, 2009 08:59 PM
DAVE15401
14
May 19, 2007 10:52 AM
