Recomended Rod Bearings for a D16Y8
Old Sep 17, 2013 | 04:47 PM
rovafa2002's Avatar
Default Recomended Rod Bearings for a D16Y8
Hi,
Im pretty sure I have a spun rod bearing, not too much knocking but its there. Which brand should I stick to?
Engine is 100% stock 1998 EX D16Y8.
If in the future I would like to go Turbo could I just throw in ones specified for that configuration? Which ones?
Thanks!
Old Sep 17, 2013 | 05:30 PM
doood's Avatar
been there done that
Default Re: Recomended Rod Bearings for a D16Y8
oem in whatever sizes you need to get whatever clearances your engine builder decides on
Old Sep 17, 2013 | 05:35 PM
jbpnoman's Avatar
OEM or ACL, whichever suits your fancy.
While you have the motor apart, you should consider getting ARP rod, main, and head bolts/studs, since you plan on boosting.
Old Sep 17, 2013 | 11:27 PM
apexi_rsx's Avatar
if u wanna do them all buy a set if u get ACL make sure u buy the duraglides. I used clevelites in my build. if u wanna just buy one bearing go to Honda. even with a slight rod bearing spun u should plasti gauge all of them to make sure your in spec still.
Old Sep 17, 2013 | 11:50 PM
jbpnoman's Avatar
Plastigauge, the tool when you only want to do the job half right!
Have a machine shop check your crank and main journals, or buy the right tools to properly spec out your bearing sizes. Having a machine shop do it will be cheaper, as long as you bring them the bare block and crank.
While you have everything apart (which you should, if you're replacing bearings), you should also have aforementioned machine shop hone your cylinder walls to remove any glazing, and spec your bore so you can replace the rings. If you don't replace the rings, and don't hone the cylinder walls, you won't get a good seal, and your engine will never run right. Then there's gaskets and seals...Hopefully you don't think this is just a "replace the bearings and slap it back together" project.
blink_977
Aug 12, 2010 11:40 AM
92hatchattack
Jun 7, 2005 09:21 AM
Sinner
May 15, 2003 11:39 AM
FR-MOB: ThE bEe GuY
Jan 10, 2003 11:36 AM
burnicq
Apr 22, 2002 12:52 AM
