Power windows Master Switch issue
Old Sep 17, 2013 | 10:17 AM
s0hayat's Avatar
Default Power windows Master Switch issue
Hi Guys I have a 2001 honda civic 4DR recently I purchase the whole interior of canadian Model Acura EL (2004) in Black. I yesterday install the interior door panels by myself which was fairly easy took me about 35 minutes to do all four doors. When I finish installing the driver's side door panel I ran into an issue the driver's side door power window master switch does not work for the driver side window only, rest ever window is working except for driver's side. Also the switch which indicate auto is not lid either. Need help any suggestion what could be wrong this is my second switch from Acura EL and both did the same thing.
Old Sep 18, 2013 | 08:39 PM
tobi7's Avatar
Default Re: Power windows Master Switch issue
having the same problem with my '92 civic. i checked the plug from the door to the body and found some broken wires, also you could just need a new master switch
Old Sep 19, 2013 | 06:32 AM
fcm's Avatar
fcm
Old Fart
Ditto the above, broken leads in the drivers door wire boot is a common problem.
Do you have a 12V test light, [not the LED type]?
The wiring is easy to test...
The first thing to check is for power for drivers window, [green lead at master switch] it is fuse 23 - 20A in under dash fuse box.
If that is good, connect the test light probe ground to the red/black and the test light probe to the red/yellow at the master switch and rock the drivers window switch, the test light should light up when switch is rocked in either direction. 94
Old Sep 19, 2013 | 06:48 AM
s0hayat's Avatar
Will try that but also when I install the master switch that was on my car it works perfectly ok its just the switch that came with the door panel for 04 acura el is doing that and its my second one. But thanks anyway will try this route first and see.
Thanks again
Wheely
Dec 6, 2017 10:48 AM
JAD
13
Oct 1, 2016 04:05 PM
SoL_ger
Nov 23, 2014 09:47 AM
jaredvabeach
Honda Civic (2001 - 2005)
Apr 19, 2009 01:10 PM
AddictedTo5
Jul 25, 2008 04:43 PM
