97 ek b16 cel code 4 limp mode
Old Sep 13, 2013 | 03:31 PM
Hicksayyy's Avatar
Default 97 ek b16 cel code 4 limp mode
I have currently done a obd1 b16 swap in my 1997 civic dx. I now have everything hooked up and wired in and its in limp mode. I have a cel code 4 on and I can not figure out what I did wrong. I have tried a p61 ecu and a p30 ecu and also 2 distributers. I have looked over the wiring 1000 times and cannot find anything worng. Please help. I need my car.
Old Sep 13, 2013 | 04:48 PM
Hicksayyy's Avatar
Default Re: 97 ek b16 cel code 4 limp mode
Also I have tried 2 different clusters and the rpm gauge on either of them works. I'm thinking these 2 problems are connected. Help please!
Old Sep 13, 2013 | 07:03 PM
jbpnoman's Avatar
How exactly did you do your OBD1 wiring?
Also, you have an EJ6, not an EK.
Old Sep 14, 2013 | 06:26 AM
Hicksayyy's Avatar
I used my stock obd2a harness and I just converted the plugs.
Old Sep 14, 2013 | 07:26 AM
jbpnoman's Avatar
So you depinned and repinned it yourself? You messed something up. Either repin it back to OBD2A, and run an OBD2A distributor, or repin it back to OBD2A, and buy a conversion harness.
Old Sep 14, 2013 | 07:51 AM
Hicksayyy's Avatar
I have looked over this distributer wiring 100 times because I also thought I messed something up and nothing is wrong.
Old Sep 14, 2013 | 09:20 AM
jbpnoman's Avatar
If you have tried multiple distributors and still have the problem, it's obviously in the wiring.
Old Sep 14, 2013 | 10:47 AM
Hicksayyy's Avatar
So what should I be looking for in my wiring?
Old Sep 14, 2013 | 11:00 AM
jbpnoman's Avatar
You should look for damaged, improperly pinned, or disconnected wires. A voltmeter would be your best friend right now. Or just return the harness to stock, and run a proper dizzy, or an adapter harness.
Old Sep 14, 2013 | 12:05 PM
Hicksayyy's Avatar
So when I'm using my voltmeter what should I be looking for in the wires?
Old Sep 14, 2013 | 02:33 PM
jbpnoman's Avatar
Minimal resistance through the plug, and minimal resistance from the plug to the ECU. Good money on you having wired something wrong, still.
Old Sep 15, 2013 | 06:08 AM
Hicksayyy's Avatar
Okay so when I go and check for resistance what numbers should I be looking for. And would this make sense why my rpm gauge isn't working?
Old Sep 19, 2013 | 12:13 PM
Hicksayyy's Avatar
I figured it out.. I had to of the blue distributer wires back words.. Works great now.. Thank you
hellcatjdm
Dec 29, 2012 03:15 PM
Hoffer 10
Engine Management and Tuning
Aug 20, 2012 10:02 PM
vtecpsyco
Oct 23, 2005 12:43 PM
Capt. Jimbo McSubipants
Apr 6, 2005 09:01 AM
