96 Civic hatch wont start after alarm removal
Old Sep 11, 2013 | 10:52 PM
pnwjdm's Avatar
Default 96 Civic hatch wont start after alarm removal
Hello guys i recently bought a 96 hatch and decided to take the alarm out. i took everything out that wasnt oem and i fixed the starter and ignition wires with connectors.
Heres the problem:
The car ran fine with the alarm but after i removed everything its not starting up now. it just cranks. i do have spark but i think its the fuel delivery problem because i sprayed in some starting fluid in the intake and it fired up and died. I went towards the rear and asked a bud to turn the key but i cant hear the fuel pump priming. also the main fuel relay just clicks. what can it be? main relay? i have no clue im sure i got every part of the alarm out. thanks
Old Sep 12, 2013 | 03:18 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: 96 Civic hatch wont start after alarm removal
More than likely the alarm had the starter kill option wires were connected to the alarm module. Make sure those wires are reconnected.
Old Sep 12, 2013 | 03:31 AM
grumblemarc's Avatar
The Grumpiest
You took it out and it's still doing it's job just as if a thief ripped out all the wiring. You missed something obviously. Return ALL the wiring to stock.
Old Sep 12, 2013 | 07:53 AM
pnwjdm's Avatar
im pretty sure i took everything out. I fixed the starter and ignition wires so the engine does crank and there is spark. I cant find anything thats connected to the fuel system
Old Sep 12, 2013 | 09:12 AM
pnwjdm's Avatar
bump
Old Sep 12, 2013 | 09:20 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Check all the wiring again, you probably missed something. No use in bumping a thread after 1 hour either.
Old Sep 12, 2013 | 12:31 PM
instrument's Avatar
obviously there was a fuel shut off, your task is to find those wires....theres pretty much no other advice we can give you.....feel free to keep typing bump.
Old Sep 12, 2013 | 12:37 PM
pnwjdm's Avatar
do you know where they can be? ive tried following the wires but cant find anything
Old Sep 12, 2013 | 10:01 PM
pnwjdm's Avatar
So yes me the wiring noob found the source of the problem. I found kill switch wiring spliced right by the fuel pump plug. I didnt follow the wires since i would of needed to pull the side covers. I just used a butt connector on the two wires and wrapped in electrical tape. Car starts up now perfectly.While i was already fixing the wiring and stuff was open i went a got a updated pgm-fi relay for 25 bucks. worth it IMO thanks for the help guys i really appreciate it.
SiiRBrooklyn
Dec 28, 2017 09:50 AM
TurboEK9Coupe
Jan 17, 2009 07:03 AM
raphael
Oct 9, 2006 04:37 PM
CrotchRocket
Jul 13, 2002 07:42 AM
