voltage from vss to speedometer, 5v?
Old Sep 8, 2013 | 06:27 PM
myrustbucket's Avatar
Icon2 voltage from vss to speedometer, 5v?
I have been on this issue on my 1994 civic dx for months now and I want to get the dash put back together.
speedometer quit working one day and I have tried the following
replaced the vss, instrument cluster, cleaned ALL connections in car and under hood, traced all wiring for grounding issues (nothing), checked all fuses, scan tool - no errors, and finally tested to voltage back to cluster and was getting about 5v at the contacts.
I have another cluster that I will be able to test out later this week, but is there something I missed. ECU bad? I'm at my wits end, but I gone too far to give up. Any suggestions?
Old Sep 8, 2013 | 08:29 PM
nub's Avatar
nub
Default Re: voltage from vss to speedometer, 5v?
Does your CEL work and are you getting a VSS code?
To test the VSS jack up the drivers front wheel, connect a volt meters negative lead to the ecu A26 terminal and the positive to B10. Turn the ignition to the run position (key on engine off) and rotate the front tire by hand. Your meter should read a pulsing 0-12V if the VSS is functioning.
chad
Apr 13, 2009 06:43 PM
d_EG COUPE
14
Apr 10, 2009 01:15 PM
chad
Apr 7, 2009 03:04 PM
ma_rio44
11
Jul 15, 2007 09:24 AM
hondaboy4life
Oct 9, 2006 09:35 AM
