failed smog. 97 del sol/d16y8.
Old Sep 6, 2013 | 06:35 PM
mish__'s Avatar
Default failed smog. 97 del sol/d16y8.
Its a sad day, had to get a smog check for my tags and I failed. Badly. Epic fail.
car is a gross polluter now ): guy said it did poor in 15 mph and his scanner wasnt reading my ecu, no communication.
Any ideas how I failed so miserably?
And my option 50a fuse was no good. Could that be it?
Old Sep 6, 2013 | 07:54 PM
Former User's Avatar
Default Re: failed smog. 97 del sol/d16y8.
Check fuses 43 and 47.
Your engine is running very lean. Have you replaced the fuel filter?
Have you jumped the service connector to check for CEL codes that way?
Old Sep 7, 2013 | 03:17 AM
jbpnoman's Avatar
Like RonJ said, your motor is running lean. What trim is your Del Sol? Are you using your original injectors, or are you using the Y8 injectors?
Old Sep 7, 2013 | 07:30 AM
mish__'s Avatar
I will check those fuses, but i've checked all my fuses twice and they were good. Except I was missing the option fuse 50a but replaced it when I got home, do you know what that fuse is for?
Yes I have jumped my service connector for cel codes before if you mean the blue connector under the glove compartment.
no I havent replaced the fuel filter. I will go through the paperwork that the original owner had on his maintenance upkeep. I did smog this car when we got in 2012 and it failed, so the shop had us replace the o2 sensor and cat, then it ran straight 0s. Surprised only after a year, it failed as a gross polluter. How often should the fuel filter be changed?
Old Sep 7, 2013 | 07:31 AM
mish__'s Avatar
I have a stock y8.everything is stock on the motor
Old Sep 7, 2013 | 07:37 AM
Post pictures of the location of the 50A fuse.
Voltage test the specific fuses I mentioned. Click the fuses link in my signature.
And...what exactly happened? Have you jumped it recently? Details are needed if you want help.
The filter costs $20. It may have become clogged since the last replacement.
Whenever the fuel pressure drops below spec.
Note that the fuel filter/pressure is the first thing to consider, but there are other possibilities, particularly the ECU communication issue that MUST be resolved.
Old Sep 7, 2013 | 08:40 AM
mish__'s Avatar
I jumped the connector last time and I believe it listed missfires in cylinder 2 and 4
Old Sep 7, 2013 | 08:56 AM
This information should have been included in your first post. Post the actual code numbers. How about if you jump the connector NOW? If you reset the ECU, do the same codes return?
...and answers to other questions?
Old Sep 7, 2013 | 10:32 AM
mish__'s Avatar
My voltometer isnt working so I have to get another one.
so here goes my underhood fuse box:
when I was wiring push start. The ignition fuse blew because I accidentally crossed wires. So I took option 50a out to put in my ignition fuse holder and rolled like that. I smogged my car without the option 50a fuse thats why I asked what is that fuse for, hopefully that's not what caused their machine to not be able to communicate with my car's computer. After I got my car smogged, I went to napa and picked up another 50a fuse and replaced it. I know without it, my power windows and doors didnt work.
Now every fuse works (only determined by indicator light) and everything works as well as better. As electrical goes but pretty sure crossing the wires messed up my alarm because its not working anymore. Its a viper alarm.
smogger thinks I failed communication with ecu because of some of my mods. Push start, alarm, and no stock steering wheel. I did not wire my alarm, a shop did
Alarm:
But, I did wire my horn and srs light bypass with a reputable diy on hondatech.com:
And I wired my push start exactly like this diagram:
I reset my ecu 2 days ago. Codes were: 72 and 74. It hasnt returned yet.
I just checked original owner's maintenance papers. Last time the fuel filter was changed 2009. Should I go about replacing it? And I guess it did fail for being lean as well in 2012. Literally spent 660 at a shop for a new cat and o2 sensor last year. I cant believe it didnt pass this this time around.
Old Sep 7, 2013 | 10:42 AM
grumblemarc's Avatar
The Grumpiest
This is why some issues never get resolved on H-T. People leaving out information like this or not mentioning what has been done to the car in the first post, regardless if you think it's relevant or not.
What other things are wrong with this car?
Old Sep 7, 2013 | 10:48 AM
mish__'s Avatar
Thats it.
Old Sep 7, 2013 | 05:44 PM
tyb's Avatar
tyb
he means what else have u put on it...
steering wheel has nothing to do with it
alarm has nothing to do with it
Push start is useless in civics, its just an extra "flashy" thing, u still have to use your keys.
there's obviously something else going on
if fuses are good and you're using your same injectors
change all filters in the car (fuel, oil, air, cabin air, all that)
clean out the cat
otherwise there's something else going on
Old Sep 7, 2013 | 06:23 PM
canadaek's Avatar
clean out the cat ??? how the hell would a hollow cat help with smog????? tyb you really need to quit posting this crap some people actually try and help fix stuff here
Old Sep 7, 2013 | 06:25 PM
tyb's Avatar
tyb
obviously you haven't "cleaned" a thing in your life
clean does not mean hollow out it means clean
read before you post d***
Old Sep 7, 2013 | 06:27 PM
mish__'s Avatar
clean out the cat
N o t h I n g e l s e.
that was it.
Spark plugs replaced 2012.
cat replaced 2012.
o2 sensor replaced 2012.
Air filter replaced 2013.
this car motor is stock. No mods.
And before you go calling push starts a "flashy thing" find out the reason before judging. Mine is for security purposes, its not out in the open. And I know plenty of people in my area who has had their ignition destroyed so they installed a push start. Theres always a reason for a mod not just for little fan boys.
And if some people do mods because they like it even if its "rice" I respect that too. Cant stand when honda people cant help but bash.
Old Sep 7, 2013 | 06:29 PM
tyb's Avatar
tyb
that was it.
cat replaced 2012.
ok man
i try not to bash people its happened to me too many times
i thought u could still start your car with the key
that's the only kind of push button i've seen in a 6th gen
ok then i got no more ideas
HairyHarry
37
May 3, 2016 06:16 PM
Tripletsix
Jul 11, 2015 04:34 PM
mish__
Sep 19, 2013 11:46 PM
aux102
May 31, 2013 08:12 AM
96ls
Mid-Atlantic (Sales)
Nov 5, 2008 01:17 PM
