oil on spark plugs
Old Sep 6, 2013 | 05:50 AM
scott757's Avatar
Default oil on spark plugs
Hey guys , got a 93 civic gsr motor w/ bolt ons . Lately car has been bogging down on light acceleration so I pulled the spark plugs and they were covered in oil . The spark plug wires also had a weird lean smell to them , any suggestions as to what could be the cause ?
Old Sep 6, 2013 | 08:16 AM
Honda Garage's Avatar
Default Re: oil on spark plugs
if there is oil around the spark plug by the tip then your engine should have smoke coming out thru the exhaust pipe...that usually indicates bad piston rings on that cylinder...they are allowing oil to pass thru them and up into the cylinder
Old Sep 6, 2013 | 05:02 PM
scott757's Avatar
so piston rings ? I was told it could also be valve seals
Old Sep 6, 2013 | 05:17 PM
grumblemarc's Avatar
The Grumpiest
Leakdown test.
Old Sep 6, 2013 | 09:35 PM
Marstone's Avatar
I have the same problem with my civic 97. One of the spark plug has oil in the tip. Small amount of white smoke is coming out the exhaust. Help Guys!
Old Sep 7, 2013 | 12:55 PM
Ajdm98's Avatar
I have a turbo ls teg same problem.. it has not effected the car so much tho. check the valve cover gasket they have a tendency to go. a leak down test and compression test will tell you if your rings are really bad or not. i have 170 across the 4 cylinders and its burn 2 quarts in between oil changes still runs like a tank 130k
Old Sep 7, 2013 | 03:52 PM
The Grumpiest
Probably valve stem seals. Doubtful it is the VC gasket.
Old Sep 9, 2013 | 12:11 AM
Marstone's Avatar
I have around 180 compression test result on the affected cylinder guys. Sorry, just a newbee on car troubles.
mafia
Mar 26, 2010 10:13 PM
Snowman3645
11
Dec 4, 2009 08:02 PM
superslow-oto
Jul 7, 2008 06:52 PM
bungalo101
Apr 3, 2008 11:25 AM
Mr. Softee
Nov 16, 2001 05:25 PM
