Honda CR-V & Element 2WD & 4WD Element & CR-V
CRV OBD1 A/C Fan problems
Old Sep 4, 2013 | 03:28 PM
gefi's Avatar
Default CRV OBD1 A/C Fan problems
Hey guys , i need some help . Installed gsr head on my rd1 , converted it to obd1 - tuned it . And everything seems ok , but it is not. When i press the Ac button , the compressor kick's in but the fans do not. So i though something must be wrong with the fans , troubleshooted everything and it is ok , so then i just put my old ECU in and VOALA , fans work ? So what is the deal with the obd2 fans ok obd1 not ok ? Everything is wired correctly , double-tripple checked ... Any help would be greatly appreciated .
Old Sep 4, 2013 | 06:40 PM
gnxpro24's Avatar
Default Re: CRV OBD1 A/C Fan problems
Ecu jumper might not be wired to accept a/c input
Old Sep 4, 2013 | 07:30 PM
gefi's Avatar
It is not a jumper harness , i cut-soldered everything ... using a jumper just to revert back to obd2a. Think i found were the problem(the way obd2 a/c system is wired) is though , will write back after i test.
Old Sep 5, 2013 | 12:51 PM
gefi's Avatar
Yep problem solved , it is like this - obd2 puts out signal to FANC after the ACS switch is pushed , obd1 does not , so u have to wire a12 FANC to A15 ACC and put a DIODE between them - the diode is important cause if u make it without it , when the ect switch turns the fans on , the a/c compressor with engage too Hope i helped some of ya
mcloven
Jun 30, 2008 06:54 PM
so simple
Mar 3, 2007 08:12 PM
bigtimlikewhoa
Nov 12, 2005 06:57 PM
2muchGT
Oct 17, 2003 01:06 PM
quikB18B
Apr 14, 2002 08:48 AM
