while trying to crank car on it wont start and makes a bog noise
Old Sep 3, 2013 | 07:41 PM
B20HmongHatch's Avatar
Default while trying to crank car on it wont start and makes a bog noise
hey guys i have a 94 4 door integra with a LS vtec in it. i replaced my valves in it because i had a bent valve, my set up so far is, polished ls block with b16 pistons, jdm SiR b16a head port and polished, stage 2 clutch, b17 mani. arp head studs and just 4-1 headers.
well anyways as i was saying, i replaced the valves and put my head back on, did the timing without a timing gun but we seemed to do it pretty well. but while im trying to turn the car on IT WONT TURN ON, and it cranks kinda weird and fast and also makes a little bog noise while its cranking. it'll crank and bog like bop bop bop bop bop for every time it cranks, car doesnt turn over at all!!
anybody have this problem before or might know what might be wrong? IM STUCK! first time i ever seen or heard of this happen before!! HELP! =[
Old Sep 4, 2013 | 12:31 AM
m4xwellmurd3r's Avatar
did you have your valve seats checked when you put in the new valve? and how did it bend in the first place? I bent every valve in my head and most of them werent bent enough to tell till I pulled them out.
also did you make sure your firing order is correct?
cranking too fast is usually from no/bad compression.
Posted from Honda-tech.com App for Android
Old Sep 4, 2013 | 06:30 AM
fcm's Avatar
fcm
Old Fart
Default Re: while trying to crank car on it wont start and makes a bog noise
Ditto the above^^^.
The first thing I would do is confirm valve timing is correct. 94
Old Sep 4, 2013 | 08:16 AM
Creator's Avatar
Last time I had the bog noise while trying to start I had dropped three valves in Cyln # 3.
Old Sep 4, 2013 | 10:06 AM
well i racing a boosted eclipse on the freeway and i was smashing on him than at 7k rpm in 4th gear my car just died and wouldnt start. checked my compression and cylinder 2 was very low, so took off my head and a intake valve was bent. so i replaced it, lapped it. and it was all good to go.put on my head, now im not sure what can be wrong. could it be timing?
Old Sep 4, 2013 | 10:44 AM
jdmjunkieXL's Avatar
is the firing order correct??? Who replaced the valve for you???
Old Sep 4, 2013 | 10:56 AM
yeah the firing order is right, and a mechanic friend of mine that everybody goes to, to do it and work on motors!
Old Sep 4, 2013 | 11:18 AM
fcm's Avatar
fcm
Old Fart
Have you checked valve timing? 94
Old Sep 4, 2013 | 12:05 PM
not sure at all.
Old Sep 4, 2013 | 02:10 PM
fcm's Avatar
fcm
Old Fart
You need to confirm timing belt has not skipped a tooth. 94
hylaxrng
Dec 17, 2013 11:03 PM
accord2civic2prelude
Nov 11, 2009 01:10 AM
89lsteg
Jul 26, 2009 09:20 AM
Jazzy Jeff 978
Jul 6, 2009 09:51 AM
zx2gotboost
19
Dec 17, 2005 10:27 AM
