valve cover gasket sealing on built engines
the guys that have agressive cams and take their valve cover off once or more a year
what do you do to keep it sealed?
ive been just tightening it dry on the head for last 2 years and its been somewhat ok but it never sealed around cam gears
do you use silicone and just rip it off every time and put new one?
I reuse my VC gasket about 3-4 times. after the 4th time it usually starts to leak.
I use silicone in the corners around the cam caps, and reapply new silicone each time I have it apart and back together.
u talking about grey silicone?
cuz its kinda sticks to rubber pretty good.
i guess its time to spend more money...
I change my gasket every time i have to take off the VC. The permetex sticks to it and stretches the gasket to where I cant re-use it anymore.
But then again, I also seal up around cam areas and havent had any leaks.
I reuse the gaskets several times, with careful prep of the surfaces before installation. Just a dab of permatex ultra grey in the corners does not ruin the gasket and seals up just fine. After a few years I normally replace the gasket but they seem to hold up well for me.
I've normally found 1-3 times removal is the most you'll get out of a gasket before it'll create sealing problems.
I have a Blue hausing I use from Audi, its not anything like a RTV type gasket sealant, it doesn't leave any of that hard stuff when pulling it off, making it nasty to clean up.
This does harden but its a soft harden. I usually use it on vtec noids, cam seals and around the upper tops of the cam caps that the vc gasket goes around. I JUST resealed my top half last night, as I was doing some part changing and I use this stuff. Its around 56 bucks for a tube, but it'll last ya all year.
Honda bond is great for stuff that isn't coming off for awhile, I sealed my oil pump with that, also some dabs of it on the oil pan corners, but removing that **** from a used gasket is a pain in the ***.. I wouldn't use that on something that comes off often.
Sounds around what i'm talking about, I can post pics of the tube if you guys like.
Future reference, From autozone a new felpro gasket set for the entire valvecover is 25 bucks. Dunno how much you consider high dollar.. but that's pocket change to have oil from spilling everywhere.
rallyeredem2
Honda Civic (2001 - 2005)
Dec 25, 2014 10:58 AM
DelsolVted
13
Jan 11, 2012 03:29 PM
hb_racer
Aug 4, 2002 11:58 AM
