hondabond question
Old Mar 4, 2007 | 12:30 PM
b20acura's Avatar
Default hondabond question
when changing the valve cover gasket where do i apply to hondabond? do i put it on the valve cover? valve cover gasket? engine head?
Old Mar 4, 2007 | 01:53 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: hondabond question (b20acura)
On the edges of the cam covers, like below where the dots are.
./0\. ./0\.
I've never used hondabond, or any sealer on the VC cover, and had no leaks.
Old Mar 4, 2007 | 04:11 PM
b20acura's Avatar
Default Re: hondabond question (CleanLikeJdm)
i wasnt planning to, but read around here and there and alot of ppl recommended it.
Old Mar 4, 2007 | 04:18 PM
1badteg's Avatar
you can use hondabond or just any gasket maker for that matter. but like whats been said just apply it to the corners of the cam caps on each end.
Old Mar 4, 2007 | 05:44 PM
RevanDA85's Avatar
I've been working with an acura master mechanic for a couple of months now and he said if you're using a gasket you should not put any sealant on there with it because it it soaks the gasket and compresses it so it doesn't seal correctly
Old Mar 4, 2007 | 06:42 PM
sauceja's Avatar
Default Re: (RevanDA85)
Sorry but
Hondabond FTMFW.
Maybe don't need it "all the time" like /\ said but if you use any gasket sealer this is the one to get.
I broke my bleeder housing for coolant on my B16 an hour before leaving for the races and found a 12mm bolt and hondabonded it in there.
Ghetto but no leaky. Its still there because I haven't sourced a housing yet.
The four corners is where I apply small amount of HondaBond on VCG. Also use it around bolt holes on oil pan gasket and on oil pump and rear main seal casing when removed and re-installed.
Old Mar 4, 2007 | 10:38 PM
sik96teg's Avatar
Default Re: (sauceja)
Yea u don't need to but I dunno y that mechanic says not to even in any honda manual its says to us gasket maker. I always use it jus so u don't have anything to worry about later and also I've only replace my valve cover gasket once in the last three years after pulling it of prolly about 15 times or so wit no leaks so I say use the gasket maker I didn't use it when I first replaced the gasket and it leaked on me
Old Mar 5, 2007 | 03:22 PM
sauceja's Avatar
Default Re: (sik96teg)
Yep I put a new gasket on and have pulled it off/on about 15 or so times as well. Still doesn't leak. Just a dap at the corners every time and go.
Uljima
Oct 16, 2015 01:02 AM
foowitdaredek
Mar 6, 2015 01:44 PM
rallyeredem2
Honda Civic (2001 - 2005)
Dec 25, 2014 10:58 AM
8point6
Nov 18, 2004 05:31 AM
hb_racer
Aug 4, 2002 11:58 AM
