TB help
Old Aug 29, 2013 | 01:41 AM
ArsenMotorsport's Avatar
Default TB help
I have searches with all sorts if keywords and couldn't find anything, I have in progress a crvtec it's all complete except the throttle body it's the stock ls on a gsr IM how the hll do I connect it to work properly? I have both the gsr cable and bracket as well as the ls, can't buy a gsr TB at the moment as to I'm in need of money in another area of life. Lol
Old Aug 29, 2013 | 06:51 AM
HellaStockEJ6's Avatar
5 seconds on google typing in "LS throttle body on "GSR" this is what comes up.
https://honda-tech.com/forums/showthread.php?t=2994397&styleid=14
Old Aug 29, 2013 | 09:56 AM
Default Re: TB help
I looked through that all it talks about is that you can use ls cable, I know that but how would you mount it which side, on the top or bottom of IM, left or right side, I tried on all sides but it seems that it's a hair too long and nowhere to mount it
Old Aug 29, 2013 | 07:00 PM
B_Swapped93's Avatar
Default Re: TB help
pics ? not getting your description too well.
Old Aug 29, 2013 | 07:33 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Default Re: TB help
When i had my lsv with my ls throttle cable. This is how i hooked it up and it worked.
I also used the ls throttle body and had th nastiest idle ever!! (Bounced up&down)
So i put the gsr one on and the idle was fixed
Old Aug 30, 2013 | 02:00 PM
Default Re: TB help
Ok cool thanks bro that helps a lot
Old Aug 30, 2013 | 02:49 PM
Default Re: TB help
You could have told him the part number for the bracket you're using. Why the hacked wires ?
Old Sep 2, 2013 | 07:31 PM
Shit Posts: 15
10 Year Member
Default Re: TB help
It's the stock Ls bracket. Just flipped upside down.
And the wires, It was LSV an the iat sensor cconnector on the Ls harness is not long enough to reach the iat sensor on the gsr manifold.
So I had to extend the wires. I did slide a wire connector tube over them and then taped it up.
Old Sep 9, 2013 | 12:29 AM
Default Re: TB help
Thanks bro, I ended up going and buying the gsr tb cable and bracket it idled funny with the ls tb
b20vteclsintegra
Nov 4, 2011 02:39 PM
tegsallgood
Dec 17, 2004 07:05 PM
filtereds0ul
Nov 12, 2003 09:30 PM
boostedcvc
Feb 5, 2003 11:29 AM
