94 accord vtec: wont rev past 4000
Old Aug 27, 2013 | 06:45 PM
bjones6215's Avatar
Default 94 accord vtec: wont rev past 4000
I just purchased a f22b1 accord and it won't rev past 4000 rpm in neutral or in gear. i changed the vtec solenoid and it just dropped my idle from 1500 to 500 wtf should i do next its kind of giving me a headache
Old Aug 27, 2013 | 07:22 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 94 accord vtec: wont rev past 4000
Have you checked that the crankcase for oil fill? Low oil/pressure will not let VTEC kick in.
Old Aug 27, 2013 | 08:51 PM
holmesnmanny's Avatar
also check for stored codes
Old Aug 28, 2013 | 10:18 AM
bjones6215's Avatar
I would have to check it when i get to the car i havent been driving it if its all f***** up lol but my homeboi works at acura he told me the same thing so ima change the oild and sparkplugs soon so hopfully that helps alot
Old Aug 28, 2013 | 10:27 AM
bjones6215's Avatar
Idk how to check the codes took it to autozone they only do 96 nd up my mechanic dont have a reader either
Old Aug 28, 2013 | 05:54 PM
rival12's Avatar
1994 You Can Self Jump. Codes Will Flash On your Check Engine Light Indicator (On The Gauge Cluster) Long Flash = 10, Short Flash = 1.
Jumping Is Simple. You need a small piece of wire bent in a U-Shape. Placed on the Diagnostic Plug. Turn Key to On-Position. OBD-1
Video Attached.
Old Aug 28, 2013 | 08:13 PM
bjones6215's Avatar
Video Attached.
I appreciate the advice advice. A friend of mines work for the Acura dealership here in atlanta he gave me a list of different things it could be and im goona go up the list and cross out what its not as i go starting with oil pressure!! Wish me luck, ill keep everyone posted
Old Aug 28, 2013 | 08:25 PM
rival12's Avatar
or Just check the codes which would point you in the right direction out of the gate. Your car is in Limp Mode. Engine Safety Protocol. Check Codes.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/obd1-limp-mode-question-2158380/
Old Aug 28, 2013 | 08:50 PM
bjones6215's Avatar
https://honda-tech.com/forums/showthread.php?t=2158380
Ill check it out in the am! Now i gotta find some spare wire somewhere lmao
Old Aug 28, 2013 | 10:45 PM
I gotta say most of the time the regulars in this forum know more than the Honda techs, let along any Acura tech.
But it's up to you what you want to do. Good luck.
Old Aug 29, 2013 | 05:09 AM
bjones6215's Avatar
I doubt they kno more than him he is like a hond guru
Old Aug 29, 2013 | 08:35 PM
bjones6215's Avatar
It was the oil pressure but thanks anyway
Old Aug 29, 2013 | 10:57 PM
NZXTInerTia's Avatar
LOL. No, just no.
Old Aug 29, 2013 | 11:18 PM
hope there's no damage
Old Sep 2, 2013 | 08:35 AM
bjones6215's Avatar
Me either started acting up again im all confused on this one
Old Sep 2, 2013 | 10:07 PM
It's doing the same thing ? What exactly did he do ? What did he say was the fault ? Check for stored codes. Just because it doesn't act like there's a code stored doesn't mean there isn't one. Also, this does tend to be an oil pressure problem as this issue tends to happen with vtec cars.
First thing, check under the oil pan for a dented oil pan. This can cause low oil pressure as the pickup has less access to oil.
2hondajim
12
Jan 20, 2018 02:49 PM
richiedan40
Oct 24, 2017 04:16 AM
The(704)kid
Jul 5, 2011 10:19 PM
G91EF
Jan 28, 2010 05:36 AM
purpl7duece
Aug 25, 2002 11:32 PM
