H22 Swap out issues....
Old Aug 26, 2013 | 12:57 PM
brian.d916's Avatar
Default H22 Swap out issues....
I've got a EK with a prelude engine. I bought this car as a project car, but I'm getting a little worried that it needs more than I can handle. I have four codes currently code 3, 9, 22, 41. I know one of the code is related to the car having a button you have to push before turning over the ignition, one code is a bad o2 censor, one code has to do with cylinder 1 position censor, one is related to a bad map sensor. The car is having troubles at idle, so I went ahead and replaced the map but it didn't seem to do anything... its still has a funny idle and is running very choppy. where do I go next. tps sensor? Clean throttle body?
Old Aug 26, 2013 | 05:02 PM
EsotericImage's Avatar
Retired Moderator
Default Re: H22 Swap out issues....
If diagnosing your car is more then you can handle, then you should take it somewhere who knows hondas and have it fixed.
d601
Jul 29, 2011 05:04 PM
Hanmin
11
Sep 30, 2010 10:35 AM
jdmray
Oct 20, 2007 10:23 AM
93sidelsolvtec
Jan 28, 2007 11:58 AM
shabam
Oct 23, 2006 08:31 AM
