Intermittent electrical issue - idles low; bogs; turn signals blink fast
Old Aug 25, 2013 | 06:39 AM
Xathine's Avatar
Default Intermittent electrical issue - idles low; bogs; turn signals blink fast
My car has been acting weird for a few months now. I've been trying to find common scenarios that would cause these issues but I'm never able to manually replicate them. Seems completely random.
Every few times I start my car I'll get one of the following:
#1 - runs fine. Perfect idle, no bog, all electrical works fine.
#2 - idles low (300-400), will bog from 2k-3k rpm, and my turn signals will blink faster then normal
Anyone have any suggestions before I start throwing parts at it?
I'm going to remove the ecu and grease connectors today (del Sol, does leak down the passenger side). But the issues don't always happen in the rain
Old Aug 25, 2013 | 01:01 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Default Re: weird intermittent electrical issue
Don't start throwing parts at it! Unless you Have money to blow, then in that case take it to a shop, if not diagnose very thing first.
Sounds like a wire is not making good contact somewhere or is shortig out.
Any cel?
Old Aug 25, 2013 | 03:17 PM
Xathine's Avatar
No CELs
Stock 94 del slo
Old Aug 25, 2013 | 04:46 PM
Shit Posts: 15
10 Year Member
main relay?
Old Aug 25, 2013 | 05:49 PM
Former User's Avatar
Originally Posted by Xathine
No CELs
Stock 94 del slo
Does the CEL work?
Old Aug 25, 2013 | 06:47 PM
Xathine's Avatar
Default Re: Intermittent electrical issue - idles low; bogs; turn signals blink fast
CEL does work
Old Aug 25, 2013 | 06:56 PM
When the problem happens, does the CEL turn on?
When was the last ignition system tune up?
Have you checked all turn signal bulbs and sockets?
Old Aug 26, 2013 | 07:44 AM
Xathine's Avatar
No CELs while its happening.
Tune up done in February, less then 5k ago. (All OEM)
All bulbs and sockets look / work normal (aside from when they blink fast)
Old Aug 27, 2013 | 06:50 AM
Xathine's Avatar
Bump for weird
Old Aug 27, 2013 | 06:58 AM
Details?
You don't always see electrical problems. Voltage test wire and socket with a multimeter.
Old Aug 27, 2013 | 08:39 AM
Xathine's Avatar
Tune up consisted of:
All OEM plugs, wires, cap, rotor, all filters and fluids, pads and rotors. Cleaned IACV, Fast idle and intake. Valves adjusted and base timing double checked. Sure I'm forgetting something
A/C and P/S removed. Battery and salt test good. All bulbs reading the same while under power / blinking.
KYDelSol
Aug 6, 2012 02:41 PM
JDMReverend
Sep 25, 2008 12:26 PM
HOUSTONtx
41
Jul 17, 2008 12:09 PM
DelSolSi93
Mar 28, 2004 05:36 PM
