Denso Radiator
hello honda-techers,
I would like to know if you could recommend any radiator that is similar to Denso radiator which has a part no. like this "19000-PO3-9031". It's labeled "Made in Malaysia" with another number "MA122000-2813 5R" in it. It also has a label marked ">Honda PA66-GF30<". Mine start leaking coolant at the top and bottom part.
Its been 10K and no problems, part is exact fit.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-your-guide-buying-quality-aftermarket-maintenance-parts-your-civic-3114911/ ... but I don't know what you'll be able to find locally in your Malaysian market.
this morning i drove to one of the local workshop specializing in radiator & exhaust, and they
just replace the upper cover of the tank(the one i mention with all the part no. & label). I ask them is there anything inside the tank they need to replace, they said no. they said it's the top part that causing the leakage..
You can buy the OEM radiator straight from Denso for much cheaper in a Denso box. Look up the Denso part number on the Denso aftermarket website. Then plug that part number in at sparkplugs.com
http://www.densoautoparts.com/find-m...icle-selection
http://www.sparkplugs.com/category.aspx?zcid=957
curious question, are the 96-98 vs 99-00 denso radiators the same? cos the part numbers are different :
http://www.hondapartsunlimited.com/o.../19010-p03-505
http://www.hondapartsunlimited.com/o.../19010-p2f-a01
also on the densoautoparts website it only has a listing for 99-00 denso radiator for the civic SOHC.
