rear main seal replacement!
Old Aug 19, 2013 | 06:13 PM
Cashmoney061596's Avatar
Default rear main seal replacement!
so i need to replace my rear main seal. I've never really worked on cars much but I'll have help. Nonetheless, I just need someone to lead me in the write direction as to what i should be doing. A good writeup would be nice. and for specifics, i've got an si tranny on a d15b, but if anyone could help me out with that it would be greatly appreciated. Thanks in advance!
Old Aug 19, 2013 | 06:19 PM
OrangeChrome's Avatar
Default Re: rear main seal replacement!
let me google that for you:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-d16y8-rear-main-seal-2584570/
It's going to be a little different as that's a y8, but if you do some more research you can probably figure out any differences there might be
Old Aug 19, 2013 | 06:20 PM
B_Swapped93's Avatar
Well you're going to have to drop the trans which is not a beginner task and by the sounds of it you're not ready to do it. good diy posted above tho look threw it
Old Aug 19, 2013 | 06:50 PM
EJ8mike's Avatar
Good luck. Mine's been leaking forever, but its very slow so i just leave it and top off every once in a while.
Old Aug 20, 2013 | 04:40 AM
DeLSoLRo's Avatar
Good luck.
Old Aug 20, 2013 | 05:43 AM
Eg.ls.turbo's Avatar
Things u have to take apart to get to rear main seal: while car is jacked up on stands, first drain tranny fluids, take off front wheels, axels, shift linkage, any sensor/ ground wires connected to the tranny, tranny mounts, bolts from the tranny to the block, flywheel, pressure plate, and clutch. And IMPORTANT THING is you'll need a jack to hold up the tranny and slide out underneath. If u don't have one underneath it then ur tranny can fall and crack the tranny.
Not as easy as u think.
Old Aug 20, 2013 | 06:28 AM
DeLSoLRo's Avatar
I found over 6 DIY's by a simple google search "replace clutch civic" in less than 5 minutes. Seriously OP. If this is a daily driver I would wait till you have 4-5 days off to do this, and while your at it you have the option to replace any of the following: the clutch, flywheel, throw out bearing, input shaft bearing and seal, oil pan gasket, get yourself an energy suspension shifter bushing set, and you can also replace the motor mounts, axles, brake rotors/pads or ball joints; if theyre bad since most of these things are coming off anyways. Something to consider. Bold items I would personally replace if I was doing this job.
Old Aug 20, 2013 | 06:34 AM
mechanix619's Avatar
1st question. Why do you think the rear main seal is bad?
pityocamptes
Nov 6, 2012 04:00 PM
dave1mcfly
Mar 29, 2009 08:26 PM
integ401
May 24, 2007 06:35 AM
91crxturbo
Sep 1, 2006 09:38 PM
CivicTuneR95
Jan 13, 2003 10:17 AM
