REAR MAIN SEAL LEAK!!!!! ( help please)
Wassup guys, Most of you know I just did my exedy clutch and rear main seal on the frankienstein (sp) Today I went to have my Exhaust put on and Huge oil puddle mechanic said more then likely rear main seal, but WTF I just put in a new one. Maybe Crank shaft? Not sure Help me out. TIA
Re: REAR MAIN SEAL LEAK!!!!! (CivicTuneR95)
Did you even get under the car to see where the oil is leaking from? If its coming from where the rear main seal is, then thats probably what is wrong.
Oil leaks aren't normally aren't that difficult to locate when they are causing "huge" puddles.
Figure out where it is coming from and I can walk you through replacing whatever needs to be replaced.
EJ1 wilcox
02-14-2005 10:30 PM
