How the heck do I get this bolt out of my rear suspension linkage.
Old Aug 9, 2013 | 06:01 PM
specialone70's Avatar
Default How the heck do I get this bolt out of my rear suspension linkage.
See that bolt? It won't budge. We took out the sub-frame with the linkage still in it and then we tried using my neighbor's 20ton press to push it out, but it just bent everything to heck. I've tried getting a similar bolt out before from a sub-frame from a salvage yard, but we ended up just cutting the bolt in half because it wouldn't budge either. Is it supposed to come out at all? How the heck am I supposed to replace my rear sub frame? Thanks. BTW this is a 92 accord. The picture is of the rear suspension. One link is taken down and out of the way for you to see better.
http://imgur.com/T2sfykc here's another link if that one won't work.
Old Aug 9, 2013 | 07:23 PM
NZXTInerTia's Avatar
Default Re: How the heck do I get this bolt out of my rear suspension linkage.
I don't see anything.
Old Aug 9, 2013 | 07:43 PM
MAD_MIKE's Avatar
MM Gruppe B
It is most likely that the bolt has rust welded to the inner crush sleeve of the control arm bushing. Easiest thing would be to use a sawzall to cut the bolt on either side of the bushing so you can remove it.
Old Aug 9, 2013 | 08:35 PM
Yeah that's how we got the bolt out of that one we pulled out of a salvage yard. At least it shouldn't be as hard to put it all back together.
Homotor
Mar 21, 2008 12:47 PM
yOnKiNaToR
Jan 10, 2005 08:34 PM
B18G
Jan 6, 2004 08:48 PM
MeanGreenEG9
Sep 18, 2002 04:24 PM
_Shadow_
Aug 28, 2002 04:55 PM
