How much boost can a stock prelude engine take?
Old Oct 25, 2002 | 08:18 AM
youngkow's Avatar
Default How much boost can a stock prelude engine take?
Thank you!
Old Oct 25, 2002 | 08:29 AM
laughinxxx's Avatar
New User
Default Re: How much boost can a stock prelude engine take? (youngkow)
6-7
Old Oct 25, 2002 | 08:34 AM
bgod's Avatar
Default Re: How much boost can a stock prelude engine take? (laughinXXX)
anywhere from 6-10. i used to run my stock block between these figures on pump gas before selling my set-up. compression numbers were fine afterwards. ran the set-up for about 6-7 months and roughly 10,000 miles.
Old Oct 25, 2002 | 12:11 PM
577HondaPrelude's Avatar
Default Re: How much boost can a stock prelude engine take? (bgod)
5psi if ya want to be safe
Old Oct 25, 2002 | 01:36 PM
DSGB.'s Avatar
Dirty Bird
Default Re: How much boost can a stock prelude engine take? (57STS)
search button?
Old Oct 25, 2002 | 08:11 PM
rjr162's Avatar
Default Re: How much boost can a stock prelude engine take? (Blurple92si)
we're doing 9psi on stock internals and a 9:1 headgasket
Old Oct 25, 2002 | 08:17 PM
Quaalude's Avatar
Default Re: How much boost can a stock prelude engine take? (rjr162)
It depends on tuning but I wouldn't go past 9 psi without a lower compression headgasket. If anything, get a standalone since this will be the best thing you ever get and will save a lot of headaches.
Old Oct 25, 2002 | 08:54 PM
ELUD THS's Avatar
New User
Default Re: How much boost can a stock prelude engine take? (Quaalude)
agree
Old Oct 26, 2002 | 05:43 AM
BoostedH23a1's Avatar
Default Re: How much boost can a stock prelude engine take? (ELUD THS)
ehh use the search button... 6-7 safe. guys when u lower the compression that changes things. im totaly guesstimating here but youll know what im saying.. say u have 10:1 with 10 psi and u have 8:5:1 with 12 psi its gonna be about the same (estimate there is actually a formula) the piston is not compressing as much as the 10:1... u see what im saying...
Old Oct 26, 2002 | 07:08 AM
Boostless97Lude
Guest
Posts: n/a
according to F-max, you can run up to 15 psi on a stock H22 with their R-ideal headgasket, oyu just have to use an MSD BTM
Old Oct 26, 2002 | 10:13 PM
Lowness's Avatar
6-7 pounds stock
get a low compression head gasket and block guard just to be safe.
Also make sure you have enough fuel so you don't lean out.
Old Oct 26, 2002 | 10:36 PM
Anubyss's Avatar
Default Re: How much boost can a stock prelude engine take? (lowness)
7-8psi. Not too crazy about using block guards. Not really necessary to use a compression lowering head gasket either. I think money can be better spent tuning it to run well rather than on gaskets and block guards. Just my opinion.
Firedrake
Aug 10, 2004 08:17 AM
respectblades
Apr 11, 2004 08:54 AM
mrx
Jan 21, 2004 05:17 AM
swlabhot
May 13, 2003 07:58 AM
siboosted
Jul 1, 2002 06:52 PM
