boost on stock compression
Old Jun 27, 2002 | 11:31 AM
siboosted's Avatar
Default boost on stock compression
I have a 99 Civic SI w/ a JRSC running 6 PSI. I was wanting to know if that is the maximum amount of boost I could run on stock compression or if I could run 8PSI and not blow up the motor. If I have to lower compression what compression do I need to run to put 10 PSI in the motor, cause if I have to change the internals I would rather run 10PSI than 8PSI. If anyone has info or opinions please let me know.
Old Jul 1, 2002 | 05:29 PM
siboosted's Avatar
Default Re: boost on stock compression (siboosted)
hey thanks for all your responses!!!!!!!!ha
Old Jul 1, 2002 | 06:05 PM
CovertFI's Avatar
you think you are the only one to ask this question or one like it? do a search, look around
edit: the question would not be boost on stock compression, but boost on stock bottom end
[Modified by CovertFI, 3:07 AM 7/2/2002]
Old Jul 1, 2002 | 06:52 PM
ion_four's Avatar
Default Re: boost on stock compression (CovertFI)
I think question wouldn't be boost on stock compression or boost on stock bottom end, but boost on massive amounts of SC heat!!! You're going to start to lose efficiency at 8psi and probably get detonation without a water/air intercooler. do a search; someone on here has a really tight set-up with 11-psi on a JRSC...forgot who, sorry.
rsx13k
May 25, 2007 12:38 PM
one slow coupe
Mar 19, 2006 05:52 PM
dsav4shawn
Jul 17, 2005 05:18 AM
mrx
Jan 21, 2004 05:17 AM
