whats the best ecu set up to use on this ?
Old Aug 8, 2013 | 02:46 AM
1camd16y8's Avatar
Default whats the best ecu set up to use on this ?
i just bought a 99 ex with a b18c1 swap done nice no hack job , its has intake headers , exhaust and what i belive is a early year blox intake manifold . so my question is the car is running on a p2t ecu (civic si) i was told this was done for emissions reasons and that i can get the GSR ecu and just swap back and forth come time to test every two years ? so which ecu should i use i dont want to go to obd1 i want to stay obd2 . I would like plug and play if can? I belive I need to find a P72 usdm gsr ecu that is obd2b or a obd2a and use a jumper harness ???? i dont want no cel light and i want the most/best ecu for the car . please if you guys can point me in the right way would be great !!!!!!!!!!! thanks alot and im new to the form hope i posted in the right place .
Old Aug 8, 2013 | 02:53 AM
jbpnoman's Avatar
Default Re: whats the best ecu set up to use on this ?
Is this a trick question?
Get an OBD2B GSR ECU. It should be a P72, if memory serves correctly.
Old Aug 8, 2013 | 03:27 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
^ that, and that should also work for emissions.
Old Aug 8, 2013 | 03:35 AM
1camd16y8's Avatar
no trick question , i just want to make sure that i buy the right set up . and what about the GSR Immobilizer those were on the 00-01 years right ? so i would be looking for a 96-99 GSR p72 OBD2B ?
Old Aug 8, 2013 | 03:44 AM
jdmjunkieXL's Avatar
I would buy an obd2-obd1 jumper harness and run a obd1 ecu with a base map with your setup
Old Aug 8, 2013 | 04:05 AM
JuggerNaut-CTR's Avatar
Originally Posted by 1camd16y8
?so i would be looking for a 96-99 GSR p72 OBD2B ?
96-98 = obd2a
99-01 = obd2b
Old Aug 8, 2013 | 04:35 AM
1camd16y8's Avatar
I would buy an obd2-obd1 jumper harness and run a obd1 ecu with a base map , if i go this route like jdmjunkiexl posted , when time comes to go test emissions just swap back in the b16 ecu i have now and all is good correct ? thanks for all the info guys !
Old Aug 8, 2013 | 05:11 AM
What state are u in???i think u might need to have the correct ecu for a gsr to pass emissions
Old Aug 8, 2013 | 05:29 AM
tercel95's Avatar
Originally Posted by JuggerNaut-CTR
96-98 = obd2a
99-01 = obd2b
Incorrect. 96-99 Integras are OBD2A
Old Aug 8, 2013 | 05:59 AM
Fudge!!! Very rarely am I incorrect about something. Thanks for pointing that out
Old Aug 8, 2013 | 07:20 AM
1camd16y8's Avatar
i'm in illionis,
Old Aug 8, 2013 | 07:23 AM
1camd16y8's Avatar
i just want to run the right ecu for the motor . if i have to swap back and forth to the
b16 ecu(p2t) just to pass emissions im fine with that .
Old Aug 8, 2013 | 08:35 AM
canadaek's Avatar
if you use a p72 you will have a check engine light for iab because your running a blox manifold instead of the gsr snail . so a chipped obd1 ecu would be your best bet (lots of base maps out there for gsr with the iab removed)
FliiBoii
26
Nov 23, 2011 12:43 PM
JohnData
13
Apr 26, 2010 06:11 PM
ken'd
Jul 8, 2006 05:01 PM
silintegra
Aug 12, 2005 05:49 PM
mrlegoman
Aug 9, 2002 08:44 PM
