... limitations on increasing boost
Old Oct 25, 2002 | 08:06 AM
1.8T_EG's Avatar
Default ... limitations on increasing boost
... local shop said that air fuel ratio the only limiting factor... is this true or not?... they said i should be alright upping the boost as long as i am not leaning out too much, right?... (will be using a wideband to watch a/f)...
... lemme know if this is a true statement... i want more than 5.5psi!!!... hoping for 12+ psi with lower compression cometic headgasket... thanks...
Old Oct 25, 2002 | 09:17 AM
speedymon's Avatar
Default Re: ... limitations on increasing boost (1.8T_EG)
the strength of your internals also.
Old Oct 25, 2002 | 09:26 AM
1.8T_EG's Avatar
Default Re: ... limitations on increasing boost (speedymon)
... will the stock internals hold for ~12psi daily assuming that there is no detonation and my a/f are all under control?... thanks...
Old Oct 25, 2002 | 09:28 AM
PWRVTEC's Avatar
Also there are limitations on the turbos efficiency. After a certain point a turbo becomes less efficient and will not last long or perform well.
Now the other factor is detonation. 93-octane gas can only allow you to increase the boost but so much. A/F ratio is not the only factor in determining how much boost you can run. Ignition timing has allot to do with it as well, load and so on and so fourth.
But the most important thing to remember is that, "Boost is a measurement of restriction not power"
Old Oct 25, 2002 | 09:29 AM
DSF's Avatar
DSF
Another important factor (assuming this is a street car) is the octane of gas readily available. You can have a "safe" 11.5:1 a/f ratio at 30psi of boost, but something in the back of my mind says that 91 octane may not be able to resist detonating
Edit: Doh! PWRVTEC beat me to it
[Modified by DSF, 1:30 PM 10/25/2002]
Old Oct 25, 2002 | 09:34 AM
PWRVTEC's Avatar
Most likely if the EGT's are not too high, no detonation, good controlled A/F ratio, no too aggressive ignition timing.
Old Oct 25, 2002 | 09:35 AM
PWRVTEC's Avatar
Default Re: ... limitations on increasing boost (DSF)
Old Oct 25, 2002 | 10:55 AM
dustin's Avatar
Yep, fuel octane is the only real limiting factor.
Old Oct 25, 2002 | 11:06 AM
DIRep972's Avatar
Smarter than you
Default Re: ... limitations on increasing boost (dustin)
hehe dont forget about timing when u turn up the boost. u have to adjust that too.
Old Oct 25, 2002 | 12:53 PM
avividmemory's Avatar
Default Re: ... limitations on increasing boost (DIRep972)
hey direp 972, what timing are you set at?
Old Oct 25, 2002 | 02:46 PM
DIRep972's Avatar
Smarter than you
Default Re: ... limitations on increasing boost (SpoolinLS)
.7deg. retard per psi.
aalb1
Nov 15, 2005 02:09 PM
B16Civic93
Jul 13, 2005 02:12 PM
HotRodTeg
Sep 9, 2003 10:52 AM
Screamer
Apr 22, 2003 05:09 AM
