D16y8 Swap Quick Questions-Noob alert
So im buying a 2000 d16y8 that came out of an automatic car and its going into my 96 manual dx hatch that used to have a y7. i want to make the swap as painless as possible and my question is can i use a 96-98 y8 engine harness -manual of course. or does it have to be a 99-00? 2nd question is since the engine was for an auto and i use a manual engine harness do i still need to do the iacv plug switcheroo?(3 wire to 2 wire)
wont i have to do something with the crank sensor?i read somewhere the y8 crank has extra wires? and do u know of a good diy for wiring v-tech? thx
Yes you can use a '96 - '98 Y8 harness, or add vtec to your current harness. It doesn't matter which of the two harnesses you use, you'll need to do some wiring either way. Using the Y8 harness you'll need wire in the secondary O2 sensor, using the Y7 harness you'll need to wire in vtec and do the IACV fix. In both cases it needs to be a '96 - '98 harness.
You'll also need a manual Y8 intake manifold and throttlebody.
ahhhh muey bueno
the answer i was looking for!
so i read somewhere the floor harness of a 96-00 civic ex has the secondary o2 wires on it, is there any truth to that?
the answer i was looking for! so i read somewhere the floor harness of a 96-00 civic ex has the secondary o2 wires on it, is there any truth to that?
Yes there is. If you want to do a power window conversion using a '96 - '98 floor harness and engine harness makes the whole swap plug and play from an electrical perspective.
thats exactly what im doing
just need lock actuators to finish the conversion.
last question that i can think of, can i use my y7 throttle cable or do i need a y8?
just need lock actuators to finish the conversion. last question that i can think of, can i use my y7 throttle cable or do i need a y8?
Help, so I got my y8 today and it needs a distributor. so I was gonna swap the one form my y7 over and decided to look up to see if the part numbers were the same and when I look it show 2 diff. part numbers for the distributor?wth? Can someone plz elaborate on the difference. I looked it u for a 97 ex btw cuz that's what the motor is. the guy was wrong, it wasn't a 2000
30100-P2F-A01 DISTRIBUTOR ASSY. (TD-98U) (TEC)
30100-P2E-A02 DISTRIBUTOR ASSY. (TD-80U) (TEC)
Not sure but if you look throughout the 96-98 years the EX, DX/LX/CX, GX and Del Sol S/Si share this distributor. Maybe revisions or slight manufacturer differences (TEC, Westec, Weastec)?
No. the dx don't have the second alternator as an option,least not the 96. but the 97ex does. but ur prolly right. they did the same thing with the spark plug wires.
project civic
May 23, 2005 08:32 AM
