block cracked, fixable?
Old Aug 2, 2013 | 09:49 PM
TGonie's Avatar
Default block cracked, fixable?
Car was involved in an accident and the drivers side motor mount got pulled out of the block taking out the threads and cracking the bottom hole...
Since this block is sleeved im really hoping it could be welded and have the hole redrilled or something...
Anyone with experience with this kind of stuff with any input would be appreciated!
Old Aug 3, 2013 | 03:46 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: block cracked, fixable?
It can be done. Has to be tig'd out of the car. Welder has to be fairly good as the weld can be porous/brittle and crack again. Drilling the weld perfectly will be a bitch given how much harder it will be than the cast material but is doable with a decent high speed steel bit (no carbide they literally turn orange hot)
Old Aug 3, 2013 | 05:26 AM
jimbo slice's Avatar
I agree with Wantboost.
A question for you Wantboost... Should he disassemble the block before having it welded? The one time I had this done I was asked to disassemble the block to be able to clean it as much as possible inside and out. I was told the oil inside the block could start to burn through as the area being welded heats up. Was I told wrong?
Old Aug 3, 2013 | 07:13 AM
wantboost's Avatar
Who is Mr Robot?
Eh it shouldn't need to be. There's enough material for it to dissipate heat, I don't see it burning through to the water jacket or warping anything. Hell you could fill the water jacket up to have added heat absorption and dissipation
Having the motor apart would make moving it around easy but if the bottom end is healthy otherwise I wouldn't touch it. Although depending on the mileage on the bottom end a quick rebuild couldn't hurt
Old Aug 3, 2013 | 08:53 AM
TGonie's Avatar
the motor is a fresh build, maybe 2000 miles
thanks for the input, ill have to wait till its out of the car and see if anyone is up for the task
Old Aug 3, 2013 | 09:39 AM
KevinEF7's Avatar
Such a clean car to, is the ride totalled?
Old Aug 3, 2013 | 10:46 AM
Thanks for clarifying.
Old Aug 3, 2013 | 02:05 PM
EFnCRX's Avatar
Did this snap off while running? Or over torqued?
Speedy0504
Honda S2000
Jan 24, 2019 03:12 PM
HyperFlow
Aug 5, 2010 11:11 AM
preludesi93-arg
Jun 19, 2005 06:44 AM
T3mp3sT
Feb 23, 2005 03:02 PM
