93 Del Sol SI Rear Caliper Removal
Hi All,
I am having some issues with removing the rear calipers, specifically the parking brake cable. The manual tells me to remove a pin, but I do not see one. I see what I think resembles the top of a clevis pin, but it does not go all the way through or have a lock pin.
What am I missing? Do I need to remove the bracket with 2 bolts for the park brake before attempting this? Any insight would help. And if there are any pictures, that would be great.
Thank you.
Thank you.
You need to remove the dust shield first, it's covering the top portion of the parking brake cable. Once the dust shield is removed, there's a C-Clip that holds the parking brake cable to a bracket; remove this C-Clip to free the cable. The cable itself is attached to the caliper via a cotter pin that runs through a hole in a cam pin; removal of this should be self explanatory.
Angel987
Jan 23, 2018 11:05 AM
B_Swapped93
Jan 15, 2014 07:46 PM
imadigitalgod
Sep 2, 2010 10:08 AM
elnoyl
May 6, 2009 01:21 PM
