Going to build a turbo SOHC, d16z6 vs F23a1
Old Jul 29, 2013 | 08:25 AM
TreyA's Avatar
Default Going to build a turbo SOHC, d16z6 vs F23a1
Curious what the difference is in these motors, going to want a manual trans not sure what to go with for the f23 id prolly be putting a y8 trans on the d16 built block and head, I hear the y8 trans holds up better with boost vs the z6, if someone could point me in the right direction as for what motor would be best that would be very much appreciated.
Old Jul 29, 2013 | 08:28 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Going to build a turbo SOHC, d16z6 vs F23a1
OMG another one.
Please. Please. Please. Make use of all the information that is at your fingertips. There is an excellent FAQ in this forum as well as one in the Forced Induction forum. Read both of those many many many many many times and when you have a better grasp on things come back with a parts list for us to look over.
And there is no such thing as "best". Don't be that person in my sig.
Old Jul 29, 2013 | 08:33 AM
TreyA's Avatar
F23A1
This engine was used in the 1998-2002 Honda Accord LX, EX, and SE, LEV models, and in the Acura 2.3CL in North America.
Specifications
2.3L MFI 4CYL
Bore × Stroke: 86.0 × 97.0 mm
Displacement: 2254 cc
Valve Configuration: SOHC, 16 valves, VTEC
Compression ratio: 9.3:1
Max power: 150 hp (112 kW) @ 5700 rpm
Max torque: 152 lb·ft (205 N m) @ 4900 rpm
D16Z6[edit]
VTEC
Found in
1992–1995 Honda Civic Si
1992–1995 Honda Civic EX, EX-V
1992–1995 Honda Civic ESi (European Market)
1993–1995 Honda Del Sol Si (US)
1993–1996 Honda Del Sol ESi (European)
Bore and Stroke: see D16 Series Engines
Displacement: see D16 Series Engines
Rod Length: 137 mm
Rod Ratio: 1.52~
Compression: 9.2:1
Power: 125 bhp (92 kW, 125 PS) at 6,600 rpm
Torque: 106 lb·ft (14.7 kg/m, 144 Nm) at 5,200 rpm
Found this info through wikipedia
Old Jul 29, 2013 | 08:34 AM
TreyA's Avatar
Originally Posted by grumblemarc
OMG another one.
everything ive searched is from 2005 or 2008, im sorry im not lazy though i use google more than anyone i know and im constantly looking for stuff, tbh i dont use forums much but a good friend told me about honda tech
Ok, not which motor would be best but which would be better? are there good quality aftermarket parts for the f23a1, do people build these for boost, or do most just stick with the z6? and why? From what im getting of it, the f23 is basically a big block z6 i may be wrong i havn't been dealing with honda motors for very long. I have questions of my own and if its not to much trouble for someone to answer them i would appreciate it. Looking at answers to other peoples questions doesn't always pertain to my situation hence why forums like these exist
Old Jul 29, 2013 | 08:36 AM
The Grumpiest
Then you're not looking hard enough or inteh right places.
And I told you where to go IN Honda-tech. Start reading.
Old Jul 29, 2013 | 08:41 AM
TreyA's Avatar
ok i now see that its all organized in one post with links everywhere, the title of that thread made me think it would be 1000 people asking questions all over and a waste of a ton of time filtering through, i will browse through to find what im looking for thanks
JayDL
10
Apr 13, 2009 08:59 AM
BRG+Honda=JDM
May 12, 2007 11:06 AM
MugenT
23
May 8, 2005 05:03 AM
civicnar
Feb 18, 2004 08:50 PM
whoobeedoobee
Jun 8, 2003 04:50 PM
