multiple codes help
Old Jul 24, 2013 | 06:18 PM
sherrybogue's Avatar
Icon6 multiple codes help
98 civic. Codes po302
Po141
P1399
Changed coil injectors r workin
Any ideas
Old Jul 24, 2013 | 06:21 PM
Former User's Avatar
Default Re: multiple codes help
Reset ECU. Do all codes repeat?
Old Jul 24, 2013 | 06:27 PM
jbpnoman's Avatar
P0302 and P1399 are misfire codes. P0141 is an O2 sensor heater circuit malfunction.
Like RonJ said, reset the ECU, see what codes come back. If you don't feel a miss, P0302 and P1399 should go away with the reset. P0141 could be either a wiring problem, or a fault with the O2 sensor. NGK has a how-to for testing the O2 sensor on their website, here
Old Jul 24, 2013 | 06:45 PM
Did reset and codes still same car is missing, shakes at idle., at first would not start,
replaced coil, now starts, runs like crap, tested objectors all got fuek
Old Jul 24, 2013 | 06:47 PM
White spark at cyl2 spark plug?
jbpnoman's Avatar
Get a spark tester from your local parts store, and follow the instructions on it to test each wire individually.
Old Jul 30, 2013 | 05:11 PM
It was nothing more than plugs n plug wires runs like a top
blackcivic11
Aug 28, 2008 10:29 AM
sohckid00
Feb 27, 2008 06:43 PM
BlkB16EK9
May 4, 2006 12:19 AM
NYSiRacer
13
Jul 29, 2004 05:19 PM
stehigs321
11
Jan 22, 2004 03:19 PM
