Car jerks at about 1500 rpm all gears
Old Jul 24, 2013 | 04:33 PM
VXvtec's Avatar
Default Car jerks at about 1500 rpm all gears
Originally Posted by Boostn B20
hey. i went out for a test drive, i noticed my car jerks at about 1500 rpm, after that, once u get to 2800-3000 it stops. wat cud that be. i think i bled my clutch line properly, cud it be spark plugs bad, but they look good...any ideas? if it has happened to anyone else....
Dude, I got the same problem in my 93 civic right now and it's annoying as hell! I can't even drive my kid in my car without the car shaking/ jerking at 1,500 rpm in every gear. I think I'm experiencing what you're experiencing because after my swap my car did this too! My real question is how did you fix this problem?
Old Jul 24, 2013 | 11:08 PM
fasterthanueg's Avatar
Default Re: Car jerks at about 1500 rpm all gears
sounds like a tps calibration related issue
Old Sep 11, 2013 | 02:22 AM
rorroland's Avatar
I have the same problem with my car. It will jerk at 1500 rpm on acceleration and deceleration even at idle when I rev at exactly 1500 rpm it will jerk. What we did last time was adjusted the TPS and the jerking problem went away but only at acceleration. I still have a problem with jerking on deceleration the same at 1500 rpm. One of my friend told me that it could still be TPS issue. He recommended me to check the adjustment. It should be 0.5 on close throttle and 4.5 on fully opened throttle. Will try to do an adjustment and will post the result if it fix the problem.
Old Aug 23, 2014 | 06:48 AM
VXvtec's Avatar
So did it fix problem?
Old Aug 23, 2014 | 08:38 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
0.48v on closed throttle to be precise. WOT throttle is less critical and will vary from car to car. The critical part is the closed throttle of 0.48v.
Old Aug 23, 2014 | 08:43 AM
VXvtec's Avatar
So I'm lost, do I just adjust it? If so, how?
Old Aug 23, 2014 | 09:00 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You can to see if it helps.
The HOW would be found here:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/official-honda-tps-wiring-calibration-thread-2830131/
Old Aug 26, 2014 | 07:07 PM
rorroland's Avatar
@TomCat39: Yah correct adjustment on TPS solved the problem in my civic.
Old May 26, 2022 | 01:11 AM
Shruti's Avatar
Hello. My Honda City (type 2 2001 model) also showed a similar issue. I experience the jerking at exact 1500rpm while decelerating. Do you think its an issue with the TPS settings?
Old May 28, 2022 | 07:55 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I suspect a different enough car that it's not relevant to this over 8 year old thread. Please start your own thread in the Honda "City" forum where other City owners may be of help. And if your issue is TPS all info has already been posted or linked to for you to correlate it to your different vehicle.
lurkin' eg
Nov 15, 2007 08:38 PM
clean3two3
Oct 24, 2007 02:19 PM
PRoJecTSLeePaLoT
Jul 31, 2005 07:39 AM
accord00turbo
Jul 20, 2002 01:14 PM
