idling
Old Oct 22, 2007 | 11:16 AM
clean3two3's Avatar
Default idling
i noticed something my car idles at 2g around 3g rpm and other times it idles lower then that usually it never passes 1000 rpm now im noticing it goes past that when i start my car .anyone think that is going to be a problem or might think i might have a problem?
Old Oct 22, 2007 | 11:38 AM
climb_on's Avatar
Default Re: idling (clean3two3)
by 2g around 3g do you mean 2000 and 3000? then you say it doesnt go past 1000?
me and probably other people that read this are most likely confused to your question.
what did it use to idle at? and what is it idleing at now? also are you getting these numbers when the car has warmed up?
Old Oct 22, 2007 | 11:54 AM
rkrone's Avatar
you have a vacuum leak and a grammer problem
Old Oct 22, 2007 | 12:50 PM
Integrame's Avatar
Default Re: idling (rkrone)
What he said..
Old Oct 22, 2007 | 09:32 PM
clean3two3's Avatar
alright my bad i know i got a grammar problem but you have a spelling problem lol.umm ok my car when i got it never passed the 1000 rpms.once in a while my car will idle around the 2000 rpm and 3000 rpms.this only happens once in a while when i warm up my car but once it is warmed up it settles and does not pass 1000 rpm.so do you guys think that is a problem
Old Oct 23, 2007 | 06:47 AM
weavertime1's Avatar
Default Re: (clean3two3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkrone &raquo;</TD></TR><TR><TD CLASS="quote">you have a vacuum leak and a grammer problem</TD></TR></TABLE>
Too bad GRAMMAR is spelled with an A...hahahaha!!!
Clean the IACV as shown in this thread below and see if that helps...
https://honda-tech.com/zerothread/1575913
Old Oct 24, 2007 | 02:19 PM
clean3two3's Avatar
oh snaps thanks ^WEAVERTIME1 ill just do that and see whats up
yee SERIOUS
Apr 17, 2006 01:58 PM
matt j
Jan 2, 2004 07:21 AM
