Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
radiator problem blown head gasket??
Old Jul 24, 2013 | 05:14 AM
Hellsing032's Avatar
Default radiator problem blown head gasket??
hello everyone , i recently bought a 08 civic Si its rebuilt title , i noticed the whole radiator support was replaced along with radiator and when a few days after i got it i checked the coolant reservoir and it was empty , filled it up and checked it two weeks after , empty again ! filled it up checked radiator and had noticed this white residue around it ..filled up the radiator and few days after my coolant reservoir is already half empty .
my car has a check engine code for the ECT sensor , i recently found these plugs i'm pretty sure these are the ECT plugs ?
well regardless my worry is cause of the coolant that just goes somewhere cause i don't see leaks ,radiator hoses are really hot, could it be the ect sensors ? my Temp gauge shows it heat up and stays where it should
also noticed a fuse missing ?
thanks in advance !
Old Jul 25, 2013 | 05:25 PM
immajackuup's Avatar
Default Re: radiator problem blown head gasket??
use coolant pressure tester and see does it hold pressure or any sign of leaks.
Old Jul 30, 2013 | 06:54 AM
Shambler2's Avatar
If you are loosing coolant and cant tell where its going, then there is a possibility your car is burning it. I.E.Head gasket. Like ImmaJack said, pressure test your system. It should pump up and stay there. The car hates air in the cooling system and cooling sensors freak out, etc.
Smell your reseviour. Does it smell like exhaust? or ONLY like sweet smell of coolant?
maddcrx
Honda S2000
Jun 7, 2008 10:03 PM
civicsir94
May 20, 2008 03:21 AM
clean3two3
Oct 17, 2007 12:54 PM
dynastix9
Dec 18, 2005 06:33 AM
B17AGSR
Jun 8, 2004 07:23 AM
