Stock LS head Turbo dyno soon, what to expect?
Going to the dyno soon with my refresh rebuilt block. 60 trim turbo, new ramhorn manifold, 3" downpipe.
My ultimate goal is 400-500whp, but I don't think my head can keep up. Anyone have any idea when my head is going to be at its peak in performance? I understand a vtec head is the way to go, but that is not an option at this point.
I am at 300whp now, and if I cannot get passed 400whp on this head, I may not even retune for more power.
I am considering cams/springs/retainers, but am unsure. I have a feeling the gains would be minimal without the head being ported.
Any advice or personal experience stories will be appreciated.
From what I read in the past and seen from previous ls builds, your going to need cams to achieve that goal you want
Stock port head is fine but you'll need cams and supporting valve springs retainers. Other than that the 60 trim with a .63 housing should net you 425-450 with a bunch of boost. The .48 housing isn't worth a damn for high Hp. Swapping to the .63 will pick up Hp on same boost level your at now
If he goes ls/vtec he needs to source a head, gsr ARP headstuds and he needs to source a ls/v kit, then wire the car for vtec, oem gsr timing belt, oem vtec oil and water pump etc. it can really add up.
IMO as the old saying goes K.I.S.S
I did buy a .63 ar exhaust housing while back, but when I installed it, it didn't fit. The turbine blades wouldn't spin. I only paid $60 for it too but ended up selling it. I see these housings going for $200+ everywhere which is nuts, even on ebay.
What do you guys think I can make realistically? I made 293 on 14 psi on a cast iron ebay manifold. I now have a nice ramhorn manifold. I'm thinking, with the same psi on a ramhorn manifold, I am assuming I can see a good jump in power? 20, 30whp?
The doesnt really matter. The long runners put the power down low, along with the cams. So you'll be needing to run more boost to hit the same hp number not being able to rev the car out.
understood. do you believe I will gain more horsepower by swapping out my cast iron manifold for a ramhorn with the same amount of boost?
the head I have is ported with jge 303 cams. I think crower 404s are similar in grind. the guy who owned it before made 457hp at 23lbs of boost on a t3/t4 57 trim garret turbo. his limiting factor was fuel. he was close to maxing out his 880cc injectors.
the cams are a .417 lift and 274 duration. that was with a stock intake manifold and stock tb.
theres no reason why my head wont support 500hp+ with more fuel and boost.
so id say port it amd cam it, get a decent intake if you dont already and go at it. I believe he was running stock compression pistons.
I only want 350+ with 10.7:1 compression so my tune will obviously be more conservative lol.
400 with a stock head I think is right around where they hit a wall.
Posted from Honda-tech.com App for Android
I picked up about 50whp from going from a tubular log and 93 to a ramhorn and E85.
20lbs was 420whp, now its 470
