b16a 1000cc Precision injectors calibrations
Old Jul 20, 2013 | 04:53 PM
petroi77's Avatar
Default b16a 1000cc Precision injectors calibrations
hi everyone,
i'm in need of a basemap for my hondata s300v2 if anyone can help
car type civic 1995 4 door
b16a swap
2 1/2 inch exhaust system
garrett nissan rb25 turbo open at 1 bar
OMNI 3 bar B series map sensor
AEM fuel rail and regilator set at 43 psi
1000cc precision injectors
Skunk2 66mm Alpha Throttle Body
BLOX POWER INTAKE MANIFOLD up to 72mm
Golden Eagle Cam Gear Gears
Wiseco Forged Pistons Eagle Rods 10.75:1 81mm
b18c type R camshafts and lifters
ARP main and head studs
AEM UEGO Wideband O2 Air/Fuel Ratio Gauge and the Bosch 4.2LSU sensor
cometic std size and bore head gasket
ACL Race BEARINGS Kit
Vtec Gates Racing Belt Timing Kit
5 bar fuel pump
thanx
Old Jul 21, 2013 | 12:17 PM
petroi77's Avatar
Default Re: b16a 1000cc Precision injectors calibrations
Anyone. Kinda in a bind here
my problem is the car wont start with the default timing and latency settings for the injectors. even when I have them set to 1000cc
Old Jul 21, 2013 | 04:16 PM
Muckman's Avatar
Moderator in Chief
So play around with cranking fuel trim.
Old Jul 21, 2013 | 04:38 PM
petroi77's Avatar
that does not seem to help. its the injector timings that I need help with. I emailed the injector maker for the timings but I guess I must be applying them wrong
Old Jul 21, 2013 | 05:41 PM
Muckman's Avatar
Moderator in Chief
I googled "Precision 1000cc battery offset".
https://honda-tech.com/forums/forced-induction-16/crome-battery-offset-voltage-1827831/
Enter those values and adjust cranking fuel until it starts.
Old Jul 21, 2013 | 06:54 PM
petroi77's Avatar
https://honda-tech.com/forums/showthread.php?t=1827831
thanx i'll give that a try tomorrow and see what happens
Old Jul 22, 2013 | 12:24 PM
VegasInvasion's Avatar
I'm Huge In Japan
that's not your problem anyway, did you calibrate the map sensor? I'd suggest BUYING a professionally designed basemap if you don't know what you're doing, so you have something to start with.
nobody's going to give you a free one.
Old Jul 22, 2013 | 04:38 PM
petroi77's Avatar
ya I tried buying a pro tuned basemap online but it seems that they don't sell to outside the US co's they cant confirm the visa or something.
ya I calibrated the map sensor, it wasn't that complicated. I've had it running on my old engine for a while before I got this new setup. there is only one person here in my country that does dyno tuning for Honda and he's pretty hard to come by and very big headed.
I'm replacing my cold idle control tomorrow co's it seems to not be working correctly and its throwing everything I try off. my rpm is cycling thro 100 to 900 to the point of it stalling
Old Jul 25, 2013 | 12:03 AM
I'm Huge In Japan
All good tuners are big headed, it's because we're awesome and we turn turds into gold.
You can purchase a basemap from Xenocron with paypal.
If your FITV was faulty you would be idle surging a lot higher than 900 and it wouldn't be trying to die, I doubt that's your problem either.
Are you using a wideband? do you know what your fuel ratios are?
Old Jul 25, 2013 | 06:08 PM
petroi77's Avatar
as long as he turns my turd in to gold he can have as big a head as he wants lol. ya Xenocron was the first I tried. there checkout page is messed up, I email them and they just tolled me to try again, which I have done loads of times.
I've gone back to stock injectors, fuel rail and regulator with an FMU until the tuner can find the time for me. idle surging seems to have gone so its the injectors that seemed to have been the problem, theres nothing to do about that but tunning
petroi77
Aug 1, 2016 03:41 AM
petroi77
12
Oct 13, 2015 12:10 PM
petroi77
Jul 18, 2014 12:55 AM
iNDyCRX
Mar 31, 2010 07:16 PM
Chee_dog
Dec 17, 2008 06:17 AM
