Need HELP! Swapping clusters in a 95 DX
Ok so here is my issue, i pulled the old cluster and before even switching the speedo(to retain original miles) i noticed i do not have a green plug for the back of the new cluster (the one with the tach) Its not anywhere in there. Im wondering how I go about installing the factory plug or what I have to do? I can go pull a plug off a car at the local junkyard no problem
any help would be VERY much appreciated! Thanks, Trey
when I swapped my 95 dx cluster I found an ex cluster from the junkyard, it swapped over just fine... Are you talking about the male end on the wire harness or the female end on the back of the cluster?
Don't worry about the green plug. There will be one small green plug on the cluster for cruise control and if it came from an automatic there will be a second larger plug for the PRNDL.
j4s0n1337
May 7, 2011 02:20 PM
Punker1234
Jul 10, 2005 12:50 PM
itsJDMyo
Aug 26, 2003 09:51 AM
