95 Civic EX - CEL takes 5 second to 10 minutes to go out
Hi,
Have a 95 Honda civic EX. Check engine light comes on and stays on when I try to start it. Cranks but does not start. It may take 5 second to 10 minutes for the check engine light to go out. Then I hear the fuel pump turn on and the car starts up. It is worse when it is damp outside. Any suggestions?
Thanks
Thanks
Does the CEL flash when you put the key into ACC before you crank it?
How To Pull CEL, D4, SRS, and ABS Codes (with Code Lists)
Hi,
Thanks
Thanks
The cel does not flash when key in acc. The code comes up as main relay but I have replaced it with new one. no change. I will try your suggestions. BTW, how much does an ecu cost?
check craigslist. But before buying one id see if a friend or some one may let u use theres.. Also try another main relay just in case the one you got is bad also check grounds like above post suggested.
I notice that the negative side of the battery is connected to the passenger shock tower. Is this normal? If i decide to move it where would the best place to connect it? The engine? Or some other place?
Thanks
Thanks
Darrell Woods
38
Sep 20, 2015 07:34 PM
babang09
Sep 28, 2010 08:09 AM
jorgejam2001
Sep 25, 2010 06:27 PM
