CEL light takes time to turn off
Hi Guys! can someone help me on my car problem.
I own a 95' civic and lately I just noticed that every time it rains or if the weather is cold my CEL takes time to turn off thus making me wait for a few minutes before i may be able to start my car.
I have read in some post that the trouble may be due to its main relay and I've already replaced mine as well. For starters it was doing fine, shutting of in its normal pace, but as time goes by, especially when the weather is cold or is raining it goes to the same trouble of (taking to long to turn off) waiting a few minutes more before turning the CEL light turns off making starting the car longer than usual.
Please help me out anyone.
I will truly appreciate any knowledge that can be shared.
TIA!
TIA!
Re: CEL light takes time to turn off
Hi Cynical!
It does not start when the CEL light is on. I need to wait a couple of minutes or more for the CEL light to turn off before starting. I was thinking that the cause may be the fuel pump or the igniter perhaps.
If the replacement main relay is not new, then resolder it:
http://techauto.awardspace.com/mainrelay.html
Next check whether hood fuse 31 or dash fuse 24 is loose.
Also clean and tighten the G101 ground attached to the thermostat housing:
Hi Ron!
Main relay is new, I'll clean and tighten the G101 ground attached to the thermostat housing and keep u guys posted of any changes.
Thanks a lot guys!
Thanks a lot guys!
Also check the two fuses I mentioned and the main relay plug terminals for corrosion or damage.
91ef_civic
03-11-2011 08:39 AM
2LGSR
11-18-2010 05:16 PM
Civic2Fast
02-13-2003 01:56 PM
