Serious technical thoughts on the effects of altitude......
Old Oct 24, 2002 | 05:23 PM
*Boostwerks*'s Avatar
Default Serious technical thoughts on the effects of altitude......
I have been thinking over the past couple of days about the common topic of altitude and its effects on HP, and 1/4 mile times.
My theory:
Because air is a MIXTURE not a compound, there are varying ratio's of elements that make up the substance. There is not a set level of the concentration of these elements in the air we live around. With that in mind, the ratio of Oxygen, Nitrogen, and the other elements, will vary according to altitude, and other laws of nature. Also keep in mind, that each element has a different molar mass. now because Oxygen has a molar mass of 16, and Nitrogen has a molar mass of 14, Oxygen will naturally be closer towards the bottom of the mixture. At higher altitudes a turbo is compressing more Nitrogen and other elements to result in a concentration that has less Oxygen compared to the same setup at a lower altitude and same boost pressure.
Any comments?
Thanks
[Modified by Bryson, 7:27 PM 10/24/2002]
Old Oct 24, 2002 | 06:21 PM
Default Re: Serious technical thoughts on the effects of altitude...... (Bryson)
anyone?
Old Oct 24, 2002 | 06:34 PM
Prod's Avatar
Just search the web, you can get exact numbers for everything you've been thinking of...the topic has been examined thorougly by many
Old Oct 24, 2002 | 06:38 PM
Default Re: Serious technical thoughts on the effects of altitude...... (Prod)
True.........
Yet I get totaly different responses from each of my forums, and every time the topic is posted
[Modified by Bryson, 8:39 PM 10/24/2002]
Old Oct 24, 2002 | 09:41 PM
bump
Hiboost 2.0
Sep 18, 2011 06:26 AM
Ryanhooligans
Sep 13, 2006 11:25 AM
StolenTeg
Apr 15, 2006 09:46 PM
JalopySiR
Sep 15, 2005 03:12 PM
Yosshaa
Oct 8, 2003 03:54 PM
