boosting hot and high
Old Oct 5, 2003 | 04:56 PM
Yosshaa's Avatar
Default boosting hot and high
what sort of adjustments and compensations can be made for boosting in a hot and dry enviorment like arizona. arizonas elevation is also far above sea level PHX 2000 i think?
These factors would allow more boost then a cooler sea level enviorment correct?
so if u boosted say 7 psi in a cooler sea level city what would u have to have your psi at a hotter (say 20 degrees hotter and 1500 feet higher altitude) to get the same output.
(im assuming same psi the cooler sea level place would put out more whp and trq. then AZ.)
Modified by ambition at 3:43 AM 10/7/2003
Old Oct 7, 2003 | 08:21 PM
Yosshaa's Avatar
nobody?
Old Oct 7, 2003 | 08:24 PM
falcongsr's Avatar
What is this crap?
Default Re: (ambition)
as far as ambient air pressure, the turbo is going to do its best to boost to the set level controlled by the wastegate
for temperature, hotter air has less oxygen, you will be slower in hotter climates. all you can do is raise the boost to compensate, or cool the air somehow.
Old Oct 7, 2003 | 10:07 PM
Yosshaa's Avatar
Default Re: (falconGSR)
YES THIS IS WHAT I AM SAYING. but what kinda of boost ratio for a normal condotion and my given condition is what i am tryin to figure out.
Old Oct 8, 2003 | 11:46 AM
falcongsr's Avatar
What is this crap?
i personally do not raise boost to compensate. your motor is workin hard enough anyway. i just rejoice in the winter when my car is so fast.
Old Oct 8, 2003 | 03:12 PM
Yosshaa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR &raquo;</TD></TR><TR><TD CLASS="quote">i personally do not raise boost to compensate. your motor is workin hard enough anyway. i just rejoice in the winter when my car is so fast. </TD></TR></TABLE>
good answer... anyone else?
Old Oct 8, 2003 | 03:54 PM
MiraiZ's Avatar
I agree with this....Japan (home of 100% humidity and 90+ degree weather in the summer!
Now its nice and cool and the car runs like a beast!
Mr.Death
Jun 10, 2009 09:21 PM
97grnrs
Jul 28, 2008 03:50 AM
sm00thk0zz
Jul 20, 2006 06:47 AM
86si
Jul 31, 2004 10:21 AM
