Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
2006 TL stutters and dies
Old Jul 15, 2013 | 10:06 PM
Soobcrazy's Avatar
Default 2006 TL stutters and dies
So my coworker recently bought a 2006 TL that starts to die at stoplights when it's warm. It will chug accellerate poorly and will often die when he comes to a stop.
The first time this happened the dealer cleared the codes and gave it back. Still had the problem... The second time he took it back the dealer he bought the car from took it to the local Acura dealership where they replaced the MAP sensor, pigtail and the wiring harness. Still had the problem... He took the car to a mechanic he trusts who advised that he change the sparkplugs and coil packs.
My question is, has anyone experienced this problem before? Any idea what might be causing this?
Old Jul 17, 2013 | 01:14 PM
nbld1's Avatar
Default Re: 2006 TL stutters and dies
what was the code for..... sounds like an app sensor
Old Jul 18, 2013 | 08:03 AM
Soobcrazy's Avatar
The code was for P1129. They already replaced the MAP sensor and wiring harness once and the problem remains.
Old Jul 23, 2013 | 09:47 AM
nbld1's Avatar
try checking for vacuum leaks using carb spray. spray around the intake, throttle body, hoses, injectors ect. the throttle body likes to crap out, try cleaning the iac valve and ports out... or maybe swap one(throttle body) out with a know good one. check for carbon build up inside the intake plenum and make sure the egr passage is cleared. if it is a good size vacumn leak you more than likely can hear were it is comming from
Old Jul 24, 2013 | 05:59 PM
Soobcrazy's Avatar
Thanks for the replies! Coworker is out with an L&I claim right now, but when he gets back I will pass on the information.
The last mechanic he took it to said that non-OEM plugs were used and were arcing to the coils... Sounded unlikely to me, but the dealership is paying for it, so who cares, right?
Old Aug 14, 2013 | 06:46 AM
LSVTEC408's Avatar
Has all the recalls been taken care of? I know theres a recall for a fuel main relay.
Old Aug 29, 2013 | 05:05 PM
Soobcrazy's Avatar
Hmmm, I don't know... I'll have to ask him. Thanks!
Old Aug 31, 2013 | 09:12 AM
AFH-Parts's Avatar
I would check the EGR.
Demonvw
Honda Civic (2006 - 2015)
Jul 1, 2018 09:30 AM
crashsvg
Oct 27, 2008 02:57 PM
jaminze
Oct 17, 2008 06:41 AM
cbrodac0424
Apr 27, 2006 10:37 AM
H22A EG6
Feb 29, 2004 01:20 PM
