Del Sol Rear Compensator Arms
Old Jul 9, 2013 | 04:35 PM
JC_1118's Avatar
Icon2 Del Sol Rear Compensator Arms
Hi All,
I am in the process of upgrading my suspension, I have the rear suspension stripped and I noticed the RTA (rear trailing arm) bushings were shot, after further inspection I noticed the compensator arms look old, and rusted.
Do I need to replace these and the bushings? Is it worth it? This is going to be a streetable/weekend drag car. I say this to rule out the thought of me doing any type of autocross.
New Components being installed:
- Springs
- Struts
- LCA's
- Sway Bar/Sub Frame Brace (I gotta have a lil bling!! lol)
- RTA bushings
- Rear Camber Kit
Old Jul 23, 2013 | 09:22 PM
strategy400's Avatar
Default Re: Del Sol Rear Compensator Arms
I replaced all the bushings in my rear end this past week. The toe compensator bushings were by the far the easiest to replace, but I have a 20 ton press. Those bushings were also the ones that looked like they least needed to be replaced.
I also highly recommend the schley tool for replacing the trailing arm bushings. It made it so easy it was easy and I didn't have to remove the arms.
Not to jack your thread (all though it was quite dead anyway), but I am ordering some of the ingall adjustable upper links for the rear camber. I know I don't need them on the 95 del sol right? But I don't care, I drive 170 miles daily high speed and the inside of my tires are wearing so I want to dial it in for reduced highway wear. No it's not toe, I have a lifetime alignment deal and the toe has been set. Anyone with experience putting these on? My concern is if can I just jack it up, loosen the bolts and throw them on or is there going to be some concern with the spring tension? Thanks.
Old Jul 23, 2013 | 09:38 PM
98civdx's Avatar
Master Detailer
If you're already in there, you might as well replace them.
The bushings from Honda are like $16 each, or the arm $36. Not too expensive.
Old Jul 29, 2013 | 08:14 AM
JC_1118's Avatar
Hi Guys,
I ended up ordering replacements. I also got a Rear Trailing Arm extractor tool specific to the civic/sol.
Old Jul 29, 2013 | 08:40 AM
teamXteg's Avatar
Icon4 Re: Del Sol Rear Compensator Arms
Originally Posted by JC_1118
Hi Guys,
looks like it could be interesting! should post some pics man! like to see them!
Old Jul 31, 2013 | 04:20 PM
JC_1118's Avatar
Will do!!
gmcuajo1
Suspension & Brakes
Aug 6, 2015 01:49 AM
JC_1118
Dec 14, 2012 08:51 AM
Wakes4Fun
Suspension & Brakes
Jan 12, 2009 05:37 PM
Jdm93civic
Aug 15, 2003 05:35 AM
