93 Del Sol Suspension parts list... What do you recommend?
I am upgrading everything for the suspension and steering due tot he fact that I am not comfortable with what the last owner may have done. This cars purpose will be for street/drag strip use.
Parts purchased so far:
Lowering springs
Shocks
ASR subframe brace, 24mm sway bar, end links
Lca's
Front and rear camber kits.
Front Control arms
What else is needed or recommended? Also looking to replace steering components. Thanks in advance for your input.
Lowering springs
Shocks
Lca's
Front Control arms
Re: 93 Del Sol Suspension parts list... What do you recommend?
your probly gonna rear lower shock mounting bushings since there so "fun" to remove
and grease everything before you put it back on
MONROE Part # AK70
Strut Accessory Kit on rockauto
and trailing arm bushing but get the rubber ones not the polyurethane ones
MONROE Part # AK70
I'm also considering this project (suspension replacement on a del sol).
as far as I know the polyurethane trailing arm bushings dont flex at all and will wear out other suspension parts or bind rubber ones will flex a bit and not do that
I picked up outer tie rod ends for 15$ each but if u grab them and try to move them and they dont wiggle there still good
sway bar endlinks I have a bad one on my del sol that rattles pretty bad
xboxhaxorz
09-11-2016 09:00 PM
ShinotakuX
07-20-2009 06:06 PM
the.hamburglar
07-21-2007 12:55 AM
