95 Civic D16Y8; Starter gets stuck when hot.
Old Jul 6, 2013 | 03:45 AM
Ryan Lwin's Avatar
Default 95 Civic D16Y8; Starter gets stuck when hot.
My car starter gets stuck when hot. It started happening a few weeks ago. It got stuck after I drove somewhere a bit far, parked the car, killed the engine, came back to start the car. It wouldn't start. I checked the clutch switch and it's fine. Checked the pedal stopper too and it's fine. Checked the continuity of the switch and it's working. Starter is getting power also. But starter is not cranking. All the lights dim when try to crank.
Problem only happened twice in last 3 weeks or so. But today, it happened twice in same day. To fix the problem temporarily, I just step on the clutch while in #1 gear, when the car roll just a bit, I release the clutch. This fixes the problem whenever that happened. I checked the main relay and re-soldered it. But I'm not sure if it's the problem because all the lights in dash become dim as starter is draining the current. Just not turning. Sounds like it's stuck.
Any idea what's causing this?
Old Jul 6, 2013 | 04:01 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: 95 Civic D16Y8; Starter gets stuck when hot.
Bad starter. I would check all your grounds and power and clean them but more than likely its the starter going out.
Old Jul 6, 2013 | 04:36 AM
Ryan Lwin's Avatar
Could it be stuck because it's old and maybe dirty? Do you think taking it out and cleaning would help?
killrroyale
17
Jul 12, 2013 02:28 PM
MistahJuice
Jan 30, 2012 11:30 PM
mwdazzo
Apr 16, 2009 06:09 AM
slammedtegls
Sep 24, 2004 07:05 AM
strils
Oct 11, 2001 04:48 AM
